Question about Motorola Mobility RAZR V3
My motorola V3 has developed a problem.when switched on message reads insert sim. sim has been removed and reinserted several time without success. this start to happen after an overnight charge.The sim works in other phone. Can you help. Regards.
    President:
  • 2,360 Answers
You can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockarena.com/motorola-motorazr-maxx-v3/rs13wp9/
Posted on Jan 18, 2011
I am getting a random error message on my Motorola RAZR V3 Celluar phone. It says I should insert the SIM. The message goes away when I reboot, but it reappears. Can anyone help?
Remove the back cover, battery and SIM card. Wipe the SIM and the pins where the SIM card is inserted with a cloth if u can. Reinsert simcard, battery and back cover.
Aug 24, 2009 | Motorola Mobility RAZR V3
Got a motorola razr v3 on ebay. Not reading SIM card.
It may be caused that when you take out sim from old phome it has damaged, try for old one is it still working? if not then your sim is dead, also old phones made SIM-s to be bend and such SIM-s have difficlt electrical connection with new phones.
Also find if "this sim only" is activated in your phone.
It must give you signal, Insert sim card, or insert proper sim. If insert sim card warning card is damaged or have not enough good connection, if another, then this sim only is activated you first you must unlock it to work .
Aug 20, 2009 | Motorola Mobility RAZR V3
My RAZR keeps giving me the message "Insert SIM" and the SIM is a
yes, your cellphone is recognizing the sim card, sim my be damaged
Jun 23, 2009 | Motorola Mobility RAZR V3
Missing texts when switched sim cards
they are not gone just reinsert the old sim and you should have your msgs
Apr 19, 2009 | Motorola Mobility RAZR V3
Rzr v3 showing an "Insert SIM" message
if you havent already, try to remove the sim and the battery and reinsert it.....if it still doesnt work, put your sim in another handset. if the issue follows the sim, the sim will need to be replaced. if the problem stays with the phone, attempt a master clear if the handset will let you. (the master clear will reset all phone settings and delete all your info so beware)
go to MENU > SETTINGS > INITIAL SETUP > select MASTER CLEAR
***security code by default is 000000 (6 zeros)***
good luck :)
Jan 28, 2009 | Motorola Mobility RAZR V3
Motorola v3 unlock code
you gotta pay to get it unlocked.
its only a few bucks...
wirelessunlocking.com
good luck!
Dec 16, 2008 | Motorola Mobility RAZR V3
Unable to use
Do a phone reset
try holding down the power
remove the back cover and battery
(at this point briefly let up on the power)
remove the sim card
wait for "insert sim card" message
remove battery
reinsert sim card and battery
release power key when the splash screen comes up
Feb 15, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola V3 problem
remove the sim card
remove battery
if this dose not work you may need to reflash your phone
Oct 22, 2007 | Motorola Mobility RAZR V3
Insert sim and no signal
by a new mainboard or have them reflash the phone for you....this will correct the issue
Sep 20, 2007 | Motorola Mobility RAZR V3
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
95 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
