Question about Toastess TCP-6L Popcorn Maker
I have the yellow, 6L cinema popper. No instruction booklet in the box....do you have to allow it to heat up first and for how long? We turned it off after 15 minutes as nothing was happening.
2 Suggested Answers
SOURCE: Need instructions for Toastess cinema popper TCP-6L
1 tbsp veggie oil for 1/3c. corn
2 tbsp oil for 2/3c corn
3 tbsp oil for 1 cup corn
i use 2/3 c as the max because it completely fills the bowl if you use 1 cup be sure to do it in batches or the machine will over flow.
happy popping
Posted on Sep 25, 2008
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
Use
Is the heater heating? Please check it ... Plug it into the outlet ... and put your hand GENTLY on the burner to see if it heats up. Of course, if it gets hot ... remove your hand.
I suspect the heater is not functioning 'pop'erly ...
Thanks for your interest in FixYa.com
Jul 15, 2010 | Back to Basics Disney Popper PD5 Popcorn...
What kind of oil do you use with the Toastess Cinema popper? Peanut oil or vegatable oil?
vegatable oil
Sep 25, 2009 | Toastess TCP-6L Popcorn Maker
New Cuisinart Party Popper not heating
Align the tabs on the plate with the rectangular indentations on the base.
Squeeze tabs, set plate on base and release. This should lock the two pieces together.
Mar 29, 2009 | Cuisinart PartyPop Maker Popcorn Maker
happy popping
Aug 30, 2008 | Toastess TCP-6L Popcorn Maker
I have lost the instruction booklet for my Bissell Flip-It hard floor cleaner. Where can I get this info on line? Thank you.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747125
Generic problem for all Vacuums
Posted by kanerika on Jul 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can get the Bissell instruction booklet from the Bissell factory of which I will list below for you. Your local vacuum cleaner dealer may not have the instruction booklet for the Bissell Flip-It hard floor cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Popped first few times of use
Had the same problem so I tried different oils and different popcorn brands. Also found that the o-ring inside had melted and broken up into pieces that rattled when I shook the unit. A friend passed along some Theater Spice (buttery salt) from SGW.com and their instructions said to use 6 Tablespoons of Canola Oil with 1/2 teaspoon of Theatre Spice and 1/2 cup of popcorn kernels. More oil than I wanted but damn that stuff tastes good. I now enjoy using this popper again. In short - More oil.
May 05, 2008 | Toastess TCP-6L Popcorn Maker
Where can I find an instruction manual for this popcorn popper?
Go to http://www.nostalgiaelectrics.com/ and click on their customer support link.  At the bottom of their customer support page there is a box to enter the model number of your popcorn popper to get a manual.
Apr 12, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Toastess TCP-6L Popcorn Maker Logo
134 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
