Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Maytag Ice20 refrigerator
The lights on the control panel blink constantly and the flap on the ice dispenser opens and shuts over and over, but no ice or water can be dispensed and none of the controls will respond. The refrigerator will no longer maintain the correct temperatures for the fresh food or the freezer. same issue - as all those reported - flapping ice dispenser and flashing lights. now when you call the support number (800-688-9900), they tell you this is a recall item and will send the part and schedule a technician with no hassle and no charge. i received my High Voltage board (#67006389) and replaced the old one - its quite simple as described in other posts. HOWEVER, the instructions on the instruction form (#16027069) never worked. I guessed (confirmed in a previous post) the door(s) needed to be open, but i could never get my fridge to "program mode." im wondering if i have the right high voltage board. i noticed another post with the same model that had a HVB part number of 12920710. wondering if mine is simply newer, or they sent me the wrong one? anyone with a MFI2568AES have a new HVB with part number 67006389? did you get it programed?
  • jenboydz Jul 10, 2008
    I have the sam exact problem with the flapper and the control panel lighing up and blinking. I called Maytag today and they are sending someone out on Saturday to fix it. They did say that the part was on re-call and there would not be a fee. I will post again and let you know what happens Saturday as well as how cold the fridge stays or doesn't
  • Anonymous Aug 28, 2008
    I am having the same problem with the blinking lights and the ice cub door opening & shutting. How do I stop that from happening while I get the bad high voltage board replaced. It is quite annoying.
  • 254 Answers
You have a bad high voltage board and as the other user said call the manufacturer they are assisting with this problem.
Posted on Jul 30, 2008
    Problem Solver:
  • 14 Answers
I have the same model number Maytag H20 and it started doing this tonight. I put my model/sn into the Maytag's recall site and it said mine wasn't involved in the recall. What now? I'm calling them in the morning to find out more.
Posted on Nov 17, 2011
Ice flap continues to open and shut, then it sits for a while crazy blinking touch pad.
I would be looking at a new control board. Sometimes you don't know whaTthere going to do and when there going to do it when they are on there way out. The board will tell the unit the temp inside and tell the compresser to turn on or off and to make ice or not. It is the heart and if it is faulty then nothing works properley
Sep 06, 2012 | Maytag MFD2561HE Stainless Steel Bottom...
The control lights on the refrigerator keep blinking. No function for water or ice.
Unplug the refrigerator for few minutes, say 30 minutes and then turn it ON. This would reset the control board. If the problem still persists, this is an internal failure, most probably control board.If you have electronics repair experience, could read schematics, would be able to use multimeter and could keep precautions, revert and i would be able to tell you few pointers. However, repairman is recommended as it could be quite dangerous to work on these refrigerators.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2010 | Maytag MFI2568AE Side by Side French Door...
Mf12568aeb lights flashing and ice door flapping
You will have to call Maytag at 1-800-688-9900...Motherboard is bad. You can pull out the little plate at the bottom of the water/ice dispenser, then unscrew the two screw. Pull on the bottom and the panel should come out. Unplug the white connector on the left. This will stop the flapping of the ice dispenser flap.
Sep 23, 2009 | Maytag MFI2568AE Side by Side French Door...
Blinking board and flapping ice dispenser.
We called Maytag customer service and they resolved our problem and is sending us a new control board and sending out a technican to our home to install at no charge! What great service! Thank you Maytag!
Jun 11, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Ice and water dispenser for Maytag H20 not working
You need a new high voltage control board. Ive had at least 10 do this.
Oct 05, 2007 | Maytag MFI2568AE Side by Side French Door...
Panel flashing, ice door opening and closing constantly
I had the same problem, with this model and it was the high voltage control board located in the rear. Replaced the board and it is working OK. Maytag Part # 12920710 will work on this model and it is 40.00 cheaper than the one it shows when you do a parts search. It will come up 12920709. I checked with Maytag and they said 710 will work..
Sep 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
1,046 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
