Question about Remington Powder Actuated To Power Load .22 Brown #R029280
I have a Remington 476 with a spent shell stuck in the tool. How do I get the shell out?
4 Suggested Answers
SOURCE: I have a shell stuck
I had the same problem. The rim of the shell came off after trying to pry it out. I then used the short end of an allen wrench that barely fit inside the shell and put a little sideways pressure on the casing and twisted it out.
Posted on Nov 06, 2011
  • 79 Answers
Is it a spent shell? If so, try gently and carefully prying it out with the tip of a pocket knife.
Posted on Aug 20, 2011
Simple take a wood screw and insert it in the spent shell. Gently apply downward pressure while turning the screw a partial thread in. Then use a pair of needle nose pliers to pull it out using the 476's casing as a leverage point. Just did this and worked well. Allen key and pocket knife ideas did not work as the shell is too tight in the chamber.
Posted on Apr 05, 2017
I have a shell stuck in my Remington Power Actuated Tool Model 476. How do I get it out? Thanks!
Aug 20, 2011 | Remington Powder Actuated To Power Load...
Screen.comI have a remington model 476 that has a shell jamed in the chamber. How can i free it
If the shell is discharged you can try using a ramrod to push it down a little bit and get it unstuck. If it hasn't discharged, be very careful. Through a little research I found that there is sometimes a problem getting it to go off, try removing all but the stuck shell (if possible) and smacking it a little harder to see if it just won't fire that one. No matter what, be very careful.
Jun 15, 2011 | Remington Garden
Remington 476 power hammer power load stuck in barrel.
Unless you are 100% positive that the booster has been shot I recomend that you have it removed by a professional.
Mar 06, 2011 | Desa International 100PK RDN72 2 7/8" Pin
It appears that the 22 shell has become lodged in the barrel.
I'm assuming you are using something like a powder actuated nailing gun. If so the tool should come apart for just this reason. Do not try to mechanically force the spent shell from the barrel. You can damage the inside of the barrel. If you have the manual or know the brand name and model number you should be able to find a manual online that will tell you how to dismantle the tool.
Oct 02, 2010 | Remington Powder Actuated To Power Load...
Remington Powder Actuated Tool Model 476D. Ram set. Drives concrete nails with a 22 size charge. Barrel seems to be clogged. Looking for a manual that shows the interior cross section. There is not a...
the tool got stuck, after a shot, it stayed up and I cannot release it to put a bullet and a nail for the next shot, what can I do, I tried to undo the nut in the top of the tool with no success.
Mar 06, 2010 | Remington Powder Actuated To Power Load...
How do I take my gun apart? There is a shell casing stuck
What type of Gun is it? Have you ever had it apart to clean it before?
csl USMC
Nov 07, 2009 | Remington Powder Actuated To Power Load...
I have a shell stuck in the gun and can't get it out!
if it is exploded run a rod through the gun when you break it apart. if it is unexploded be careful - it's probably a rim fire cartridge. use plenty of penetrating oil.
Sep 29, 2009 | Remington Powder Actuated To Power Load...
Powder actuated tool wont fire. I think the firing pin is stuck
is this the one you hit with a hammer? if so check to see if the firing pin is hitting the shell rim at all, if it is sometimes you just have to hit it harder, and make sure your holding the shell in position with down pressure on the handle. if it is the gun model then make sure that the safety lever is is reaching the trip mechanism when you are holding it down making ready to fire.
Feb 05, 2009 | Remington Powder Actuated To Power Load...
Remington Powder Actuated To Power Load .22 Brown #R029280 Logo
253 people viewed this question
Top Remington Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Remington Measuring Tool and Sensor Expert? Answer questions, earn points and help others
