Question about Jandy AQUALINK RS TELELINK KIT
My jandy wireless control panel is now blank. There is only the small yellow/orange light which is in in the right lower corner . Is the unit dead or do the rechargeable batteries need to be replaced? Is there a master reset button somewhere else? Help please. AG
  • 6,993 Answers
unfortunately, there is no master reset button anywhere inside or on the unit.
The problem seems as if the unit is having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Jan 02, 2011
Netbook screen blinks
you have root pixels change the panel screen for a new
Feb 05, 2014 | MSI Computers & Internet
How to change battery in aqualink control
on older units top right side has a small panel with a 9 volt newer has a battery on the back of the PCB board
Sep 03, 2013 | Jandy Aqualink Rs4 One Touch Control...
HP 3015 stopped scanning. It still prints, and goes through motions of scanning, but page is blank
HELLO
First of all,
Isolate to a wall outlet and not a strip.
Remove the cartridges.
Remove the power plug and then reconnect.
Reinstal the cartridges.
Try to do a copy direct from the unit.
NEXT
Print a self test page and check for Yellow or Magenta to rule out a partially empty cartridge.
  1. Load plain white paper in the input tray.
  2. Touch the ATM button (c01671671.gif ) next to the Setup icon (c01629002.gif ) in the lower-left corner of the control panel.
  3. Touch the right arrow button (c01185072.jpg ) to select Tools , and then touch OK .
  4. Touch the right arrow button (c01185072.jpg ) to select Printer Status Report , and then touch OK .
Dec 27, 2012 | HP LaserJet 3015 All-In-One Printer
I have a Jandy Aqualink RS OneTouch Wired Control Panel. The units light is on but there is no LED display. The unit continues to operate and turn the pool pump on and off at the scheduled times,...
It sounds like the unit itself may be out. The acid test would to be to get hold of a new one and switch them out. See if you can find a local pool company to work on that for you.
Dec 26, 2012 | Jandy AquaLink RS OneTouch Wired White...
I cannot connect to wireless, it's always telling me to turn on the switch located on the front or side of the computer which i do not understand and cannot find.
Although many laptops have a wireless switch on the front bevel, more machines now have that same switch located on the F12 key. It usually will have a light that will change from blue (off) to orange (on). If you have no switch on the front, try hitting F12. If neither of these apply (or don't work), right-click on the internet window in the systray (looks like small tv in lower right hand corner next to the clock). Click on Properties and ensure that the device is Enabled.
Mar 23, 2011 | Computers & Internet
We had an intense thunder storm and lightening the other night. My indoor Aqualink RS8 has a blank screen and is unresponsive. It apparently is not getting any power. The Spalink controller is blinking...
The circuit internally have gone short.There are many other facing this same problem.Some have got this indoor panel dead due to moisture collected on the indoor panels circuit board.The panel is not very strong to handle the humidity effect.It gets short. It has to be replaced. To get any other part and also the indoor panel board please click on the link below http://poolparts2u.com/products.asp?catid=0&scatid=27 ------ Thanks.
Jul 19, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Internet connection
if there is a touch pad across the top with lights for sound mute etc. there is 1 in far right corner top right if it is orange the wireless is off touch the orange light it should turn blue if it does the wireless will be turned on ready to use.
if it does not go to control panel click on programs and unistall the hp wireless assistance and reboot the computer.
then after a reboot the wireless light should go blue.
Jun 13, 2010 | Compaq Presario 700 470024-192 Notebook
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Panel yellow light flashing and also nothing showing on screen"
Make sure outside box is in auto mode. If you pop the display off of the wall you will see four wires connected to the panel. Make sure all are connected. Next, go out to the panel by the pool and make sure the four wires are connected there. If his didnt work the next step would be to ohm out the wires. Disconnect the wires from both ends (house and pool), On one end twist the red and black together and the green and yellow together, on the other end (with a ohmmeter) check for continuity (red-black and orange-yellow). If they check out then you either have a bad display panel, or a faulty main logic board in the box by the pool. In this case just pray that it is the display panel.........
Mar 23, 2009 | Jandy Aqualink Rs4 One Touch Control...
Signal wiring for 74 sportster
CONNECT IT BETWEEN POWER SUPPLY AND THE SWITCH. POWER IN ONE SIDE POWER OUT THE OTHER
Dec 03, 2008 | 1979 Harley Davidson XLH 1000 Sportster
Jandy AQUALINK RS TELELINK KIT  Logo
122 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
