Question about Whirlpool MH7140XF Microwave Oven
I have a 1996 whirlpool over the range microwave. i.m try to replace it with a new one . but i cant get it down.... help ?????
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
look for 2 to 3 screws in the top cupboard, if you do not see any, then you have the type, where you have to look at the top of the grill and look for a round metal rods, that look like you can put a screw driver, and loosen them..
it takes 2 people to remove..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
I cant uninstall my whirlpool microwave
The mounting bolts are usually inside the cabinet on top of the microwave. They are usually allen screws or star screws.
Jan 01, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Won't heat any foods.
you have a problem with your magnetron tube, and when the magnetron tube goes bad, the diode almost always goes out with it. you should be able to order a replacement tube from your manufacturers website, if you cant let me know and ill try to help you more.
here are the steps to replace the magnetron tube, if you want to do it yourself that is. if you have a professional do it, it can be pretty costly.
  1. Unplug Microwave at least few hours before
  2. Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
  3. Remove top cover of Microwave
  4. Make sure to keep screws correctly in a place you remember what goes where
  5. Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
  6. Remove other panels around magnetron part
  7. You need to remove lot of connecting wires, should be careful to note down what goes where
  8. If possible take digital photos to refer back when you put everything back together
  9. You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
  10. Now it should be easy to remove magnetron
  11. Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
  12. Make sure put all wires properly back
  13. Now put transformer back and screw it
  14. Put capacitor panel in place and screw it
  15. This might be a good time to test the Microwave to make sure it works fine now
  16. Now cover the top panels and start to screw everything
  17. Once everything assembled put the Microwave back above range put screws from top
Dec 07, 2010 | Whirlpool MH7140XF Microwave Oven
Can't take down/unsinstall over range whirlpool microwave
You can download the installation instructions for this model here.
Essentially you'll take it in reverse order.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 28, 2010 | Whirlpool MH7140XF Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
My Whirlpool over the range microwave works but
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
xz
May 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GH5184XPQ 1100 Watts Microwave Oven Fan Won't stop running
If it's new, it should still be under warranty, so I would contact Whirlpool at http://whirlpool.com/custserv/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool microwave, intermittent blower activity, shuts down microwave
Not clear what to explain but would look at the front control switches, commond problem, to see just play with the door open and closing to see what happen's with the fan, it's probroly not making proper contact, the other problem I can thing of is bad thermal heat sensor, there should be two or three of them, you need to know the basic what they do to test them just jump them, and try the unit and see if the problem stop to see witch termal is deffective.
Hope this help
Bob The builder
Feb 07, 2008 | Microwave Ovens
Whirlpool MH7140XF Microwave Oven Logo
67 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
