Question about Philips Magnavox 51MP392H Rear Projection Television
Color problems watching a movie everything was fine then it smelt like something was burning and then we had color problems, the red makes it look like theres two noses four eyes etc.. could this be a bulb or what? .
  • Philips Master
  • 8,617 Answers
No its the convergence ICs . You will need two STK392-120 ICs and about 4 of the 6.8 ohm 1 watt metal film resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 09, 2008
The color is very dull with the exception of red everything has a red tint to it other than that the rest of the 50" screen is very dark. Watching t.v. or movies are out of the question the color is...
Thats a very common problem caused by bad CRT coolant which will need replacement to restore the set back to normal colors and brightness levels. You can get the CRT Coolant kit at www.tvrepairworld.com which fits your model. The kit contains the coolant for all three CRTs and the CD with instructions.
Jun 24, 2011 | Philips Magnavox 51MP392H Rear Projection...
My 9 year Toshiba SD310V changes color about half through the disc while watching a movie, looks real red. Is my DVD dying?
Its most likely a problem with the dvd player, old models have a color burn-in effect after long periods of use.
May 25, 2011 | Televison & Video
COLOR IS DIM & THERE IS NO RED COLORINGS, WOULD THIS BE A BULB? EVERYTHING WAS FINE UNTIL WE GOT THE HDTV SET UP. THE DVD MOVIES SEEM TO WORK FINE.
The red crt tube on your tv is going, or you need more optical fluid for the lens. Crt tubes typically run for $150-$300, and a fluid refill should be less than $100. If the tv isn't very clear or bright, even when working right, then consider just getting a new tv. These are costly to repair and will eventually begin to have more problems.
Contact me for more info.
Thanks for asking!
-Josh
Feb 26, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
Just a question about burning dvds
You dont need any extra text files they dont have any information just bogus, try using a different player to watch the videos and no I dont belive you need to include them when burning use a rewritable for a test incase!
Mar 20, 2009 | Roxio Easy Media Creator 7
Spectroniq DVD Recorder SDR-205 Disks do not play with proper col
the remote control doesn't work with new batteries
Nov 16, 2008 | Spectroniq PDV-70X
How much would it be to repair our t.v.?
The convergence chips have gone out. It costs about $300 if it's not under warranty. This is a common problem with all rear projection tv's.
Aug 10, 2008 | Samsung HCM553W 55" Rear Projection...
Follow up to JUL 9th distorted picture question
That would be the convcergence ICs and feed resistors that need replacement. Can you reply to this same post and verify that your model is the R56W36? I will then post the correct ICs and feed resistors for your model as well as a link where you can get replacement ICs and resistors with free instalation instructions with pictures.
Jul 14, 2008 | Zenith R56W36 56" Rear Projection...
Half-way burn?
Runa thorough virus scan and if nothing shows there, do a system restore...accordianman
Feb 28, 2008 | Sony (DRU720A) DVD±RW Dual Layer...
Problem with the lamp
According to Epson the led will flash red in one of two cases: Flashes red with 1 sec intervals - either the lump has burned out(We can rule this one in this case) or the lamps cover is open (try checking the cover's sensor) Flashes red with 2 sec intervals - an internal problem, I'd suggest contacting Epson's support. Good Luck
Jan 11, 2006 | Epson (V13H010L13) Projector Lamp for...
Philips Magnavox 51MP392H Rear Projection Television Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
