Question about Zanussi Washing Machines
Unstable spin cycle - Zanussi Washing Machines
Machine won't complete spin/rinse cycle - begins but error codes due to unstability
Would love to help first need entire model number second did he give you the error code pertaining to this model
Sep 04, 2014 | Whirlpool WTW6400SW Cabrio Washer
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
Clothes are still very wet after spin cycle
I would remove the front panel and inspect the electrick pump for objects. Look into the tub to pump hose for small items of clothing, as far as the to goes their are 4 bungys that will stretch and make the water slosho out. Very easy to replace but you must first push downward on the front panel and get it out yer way then pop the top. The manual is HERE
Jan 18, 2010 | Washing Machines
Washer shakes a lot when in spin cycle
I had this problem once and the cause was that one of the adjustable feet was too high so it made the washer unstable. Ensure that you're not overloading it either (check the maximum capacity).
Thanks
Nov 28, 2009 | GE WBSR3140DW Top Load Washer
NO SPINNING ALLOWED!
This will occur if the motor control board becomes unstable, due to a failed chip set or manufacturing flaw. replacing this damaged board, will fix this issue.
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not filling or agitating, during wash & rinse cycles
HI, this will occur if the timer mechanism has become unstable. you will need to replace this defective timer control module asap, if possible.
Jul 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer has excessive vibration in spin cycle
A unstable floor will cause the problem, glad you figured it out.
Mar 27, 2009 | Admiral AW22 Top Load Washer
Severe vibration during spin cycle
reduce the amount of cloth and make sure the cloth don't fix in one corner
Mar 23, 2009 | LG WM-2277HW Front Load Washer
Unstable tub
There are springs inside the unit that stablize the tub during spin. If the springs are not attached correctly the tub will be off balance. Sometimes the Balance Ring loses it's fluid due to a crack or leak and the washer will spin off balance. THis requires a service tech to dissemble the machine.
Nov 27, 2008 | Kenmore 24032\24036 Top Load Washer
Bad shacking during the spin cycle
Remove top of machine and check the centralising springs are still attatched. If springs ok tilt machine against the wall after unplugging from the wall socket and check the shock absorbers. One of them could have jumped out of the guides. If shockies are ok, check the spider for cracks/breaks. The spider is the cast part that holds the outside drum in place. To check this you will have to remove the back plate.
Nov 05, 2007 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
