Question about Dacor Preference RSE30 Electric Kitchen Range
I have a Dacor RSE30S range, the rear two burners won't start most of the time. The front burners work fine. I've cleaned the ignitors, brass rings and made sure ever thing is seated properly. What's next?
5 Suggested Answers
SOURCE: dacor range natural gas to LP
I have the ERD36 and it runs on LP. Is this purchase a used oven? If not, I would tell the dealer to order it for LP.
Posted on Jan 27, 2008
SOURCE: I need to replace an igniter on my Dacor Range (Model # RSD30)
you need to get a burner removal tool (part 87006C) from reliableparts.com/ then the burners and top come off to replace the igniter.
Posted on Aug 02, 2009
  • 4 Answers
SOURCE: Dacor Range ignitor fails..model# unknown
Is it sparking? What I have found to work well is to take a piece of aluminum foil, crumple it and use it as if it were sandpaper, to clean the sparking electrodes.
Posted on Nov 25, 2009
meztang
  • 112 Answers
SOURCE: Dacor gas range. I'm trying to figure out why it
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
Ignitors keep firing by themselves after my aunt cleaned the stove
Hi davemoo2, I would make sure that the all the burners are put together correctly .. next check to see if a selector switch may be pushed in or shorted . also check the that the ingitors are know grounded out.. let me know what you find out... kraxytech
Sep 21, 2007 | Frigidaire GLGF382DQ Gas Kitchen Range
I have a 5 burner Dacor Cooktop (SGM365) with which I am having trouble with the right rear burner not sparking. There is gas flow and the other burners are lighting just fine. I've taken the burner apart...
In the middle of each burner, there is a small brass ring that screws in the burner. If you unscrew all five and pull the knobs, the top should come off. From there you can access the electronics. Because all the burners ignite at the same time, I would suspect either a disconnected or shorted wire on your right burner or some corrosion has occurred at that burner preventing it from grounding properly.
Nov 09, 2009 | Dacor Preference SGM365 Gas Cooktop
Mar 26, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Jul 15, 2008 | Dacor Preference PGR30 Gas Kitchen Range
F6 Error
ok.. don't you any schematic manual in there...?
Jul 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Sep 21, 2007 | Frigidaire FGF326AS Gas Kitchen Range
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Aug 14, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor Preference RSE30 Electric Kitchen Range Logo
37 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
