Question about Metrologic Instruments Metrologic ScanPal 2 (SCANPAL2CB) Portable Terminal
How do you remove the battery from a ScanPal 2?
TomTom 0ne
There are 4 screws:
1. Remove front bezel
2. unscrew 4 small screws (1 hole has anti tamper tape over)
3. remove "dome" rear of unit.
4. Remove 2 screws holding speaker in
5. Carefully remove all metal tape covering electronics
6. Remove 4 small screws securing PCB to unit
7. Remove 2 screws holding black plastic battery clip
8. Unplug small battery connector from PCB board.
9. remove battery and insert new one
Nov 09, 2007 | Tomtom ONE GPS Receiver
Trying to remove the battery from my 2007 soltice
Hello robert.... Battery Replacement
Removal Procedure
Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Lower the vehicle.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable (1).
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the positive battery cable (1).
Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
Close the positive battery cable connection cover.
Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Joe
Thanks for choosing Fixya!
Jan 30, 2011 | 2007 Pontiac Solstice Convertible
Where is the battery located?
Battery Replacement
Removal Procedure
Lower the vehicle.
Remove the battery.
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure . 1737d1122299169-solstice-service-battery-replacement-procedures-158wilmingtoncarshow36.jpg
hope this helps . please rate my response.
Nov 28, 2010 | 2007 Pontiac Solstice Convertible
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
Prints lite fuzzy
You need to raise the darkness in the printers driver in its properties on the advanced tab/printing defaults button/device settings/head settings
May 16, 2010 | Zebra LP 2844 Thermal Printer
How do you remove the old car battery on a 2008 chevy impala ss? (5.3L) thanks sam
  1. Disconnect the negative battery cable.
  2. Remove the right front diagonal brace. The brace goes from the rad support to the fender area.Three bolts need to be removed.
  3. Reposition the positive battery cable terminal cover (1).A red cover over the positive cable at the battery.It pops off.You may need a screw driver to pop it off.
  4. Loosen the positive battery cable terminal nut.
  5. Remove the positive battery cable terminal from the battery.
  6. Reposition the underhood accessory wiring junction block.See steps 9-14.
  7. Remove the battery retainer bolts (1) and retainer (2).
  8. With the aid of an assistant, remove the battery.
  9. Remove the electrical center cover (1).
  10. Disconnect the positive battery cable from junction box
  11. Remove the fasteners (1) securing the electrical center board (2).
  12. Unlock the tabs on the electrical center board.
  13. Lift up on the electrical center board.
  14. Remove the fasteners (1) securing the electrical center bracket (2) to vehicle.
Oct 31, 2009 | 2008 Chevrolet Impala
Dead battery
Removal Procedure
Remove the battery.
Oct 15, 2009 | 2006 Pontiac Solstice
Battery replace tdm 850 yamaha
first remove seat then remove tank, unbolt the 2 nuts holding the fuel pump on then disconnect wiring and then wiring from battery remove 2 bolts holding in battery box and remove through whole where fuel pump was (take care with battery wiring).
Jun 23, 2009 | 2000 Yamaha TDM 850
Total power falure
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Sep 19, 2008 | Fuji FinePix S5000 Digital Camera
Metrologic Instruments Metrologic ScanPal 2 (SCANPAL2CB) Portable Terminal Logo
181 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
