I have an Easybox 802 router/modem. I have a couple of laptops connected via wi-fi, but others I cinnot get connected. When they wont connect a message of "limited or no connectivity" is returned. One of the laptops connected is the same make and model of one that will not connect. Why???
smeago1
  • 136 Answers
SOURCE: laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Posted on Jan 03, 2008
honey2509
  • 146 Answers
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
Sutibun
  • 186 Answers
SOURCE: Connecting wired Virgin Broadband through third-party WiFi Router
Clone your mac address in the router
Posted on Oct 02, 2008
dante777
  • 623 Answers
SOURCE: 2wire 2701HGV-W Gateway wi-fi modem
The 8200 by itself does not have networking capability.
This means that you cannot connect it directly to your router and give it an IP address, so others can connect to it.
The good thing is, that this printer is listed on the list for compatibility for upgrade with the wireless network kit (see here). The bad thing is - this kit costs about 70$ (see here).
A solution which does not cost anything, is to share the printer from your computer with the other computers. The downside is that the machine to which the printer is connected has to be running in order to let the others print.
If you decide to buy the Networking Kit - here are the setup instructions.
Sorry - but there is no simple (plug & pray) solution.
Posted on Feb 13, 2009
  • 31 Answers
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Posted on Apr 09, 2009
Why wont my wi-fi 4g advanced , setup
Richard we all need more information to work with
4g are you referring to mobile data on a mobile phone network. Richard ?
Setup what are you trying to setup a USB Dongle or are you connecting via a mobile phone ?
Or are you using a 4g mobile data wi fi modem hooked into each device via wi fi ?
what operating system is on your laptop ?
Dec 27, 2014 | Computers & Internet
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Wi-fi not obtaining IP address and if turn off wi-fi can not get to turn back on
Assuming you're trying to connect via wireless router. If you connect, but then aren't able to get to the Internet. I would something is wrong between the router to the modem to the wall (DSL/Cable modem) rather then your tablet device. You can connect your device to your router and you device will show it has a wifi connection, but beyond the router something may be amiss. Try seeing what you get from another device like computer or laptop. That might get you closer to your actual issue,
May 31, 2014 | Coby kyros Tablets & eReaders
How to activate facebook without wifi?
Accessing Facebook needs internet connection. Without any active connection, you will not be able to connect to internet.
Internet connection option for such devices:
Mobile phone:1. GPRS - settings will be coming from your mobile service provider, data rates will be deducted from your load credits.2. Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Laptops / computer / PSP:1. USB Dongles - this will use the gateway connection via BTS for its using the internet connection like the protocol of ISP.2. Wi-fi - Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 01, 2011 | Myphone Computers & Internet
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
Wi fi on ACER Aspire 4810T connects intermittently
Log into your router and change the channel and see if that helps. Failing that try rebooting the router to factory settings and deleting your connection from the laptop. Then start from scratch again...Hope this helps...Please let me no...
Nov 17, 2009 | Acer TravelMate 4062WLMi Notebook
How do i connect MiFi2200 to a wrt54g?
I think this won't work...the MIFI device works as a wireless router that can supply 5 connections and runs on battery which last for 4 hours for one connection then goes down as more connections are in...the MIFI was designed for mobility as the WRT54G is not...I don't exactly know what your plans are but this won't work well.
The Verizon MiFi is a combination 3G modem and Wi-Fi router that is battery-operated for full mobility. Once the MiFi has been activated (more on that later) the device connects to the Verizon Mobile Broadband network (renamed from BroadbandAccess) simply by pushing the power button. In just a few seconds, the MiFi is connected to the 3G high-speed network and the Wi-Fi router takes over. The MiFi appears as a hotspot to any device with Wi-Fi capability, and making the Wi-Fi connection is as simple as entering the network security code which is printed on the back of the MiFi. That’s it: The notebook or other device is now connected to the Verizon network via Wi-Fi. The network code only has to be entered to make the first connection, after which it’s an automatic process. That’s the beauty of the MiFi method: Push the power button and the laptop/UMPC/phone is connected to 3G.
Oct 28, 2009 | Linksys Wireless-G WRT54G Router
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Sep 29, 2009 | NetGear DG834G Router
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
