Question about Bailey Stanley 12-920 - Block Plane
Can't put back together stanley box cutter replaceing the blade
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I cannot get my Stanley 12-220 Block Plane put
Try this site Stanleyworks.com and it is a little tricky but go to the DIY section and find the FAQ on planes and you can look at a manual for this tool. Take your time it is there Let me know if you need more help. Good luck
Posted on Sep 09, 2009
  • 436 Answers
SOURCE: Loading instruction to change blade on Stanley
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part.
Now slide the yellow part back to reviel the blade folder.
Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Posted on May 03, 2011
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
How do i change the blade on the stanley box cutter fat max?
Push the blade out as far as it will go and hold in the button on the side while slideing blade in and out.
Apr 20, 2012 | Stanley Hand Tools
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
Loading instruction to change blade on Stanley FatMax box cutter
Hmmmmm.... that sounds really confusing.
Better yet... just watch this video! http://www.youtube.com/watch?v=B8Q1p-8jkyE
It's actually pretty easy! :)
May 03, 2011 | Stanley Utility Knife
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Mar 06, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley carpet cutter model 10-525 fell apart. I need to know correct assembly.
This is a terrible tool took it apart to get the blade out of the handle and haven't been able to get it back together again.
Oct 22, 2010 | Stanley Garden
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Bailey Stanley 12-920 -  Block Plane Logo
887 people viewed this question
Top Bailey Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Bailey Craft and Hobby Expert? Answer questions, earn points and help others
