Question about WYSE WT3235LE (902032-68) Network Terminal
Conection to Microsoft Windows 2003 server terminal server
Hi I have 5 wyse wt3235le terminal that start with citryx client, i don't find the way to configure it to conect to microsoft RDP client
Who can i do it?
Thanks
  • Anonymous Mar 14, 2014
    Windows media player does not see the remote source for sound. We can get system sounds through the speakers connected to the terminal just fine, problem is with Windows media player
  • 25 Answers
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Posted on Dec 18, 2008
How can i connect client computers to server where clients have no hard disk.How clients can boot and access hard drive of server?
u can connect with ur client through terminal server. for that u've to server 2003. u can see the steps that how to configure terminal server for that u've to go this link:
http://support.microsoft.com/kb/300847
Sep 25, 2009 | Microsoft Windows Xp Home Edition Sp2...
Tip
Reset a WYse WT3235LE back to Factory setting.
Hold down the G key when powering on and during the booting process to reset it back to factory settings. You can also do this in Control Panel under System.
NOTE: The G key trick is very picky so make sure you hold the G key before you press the power button and until it is booted. Also don't be frustrated if it doesn't work the first time.
on Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
Thin Clients Have a Problem Connecting After Activating Licensing
Try using the command "fixlicense=clean" (think thats how its spelt, check with Wyse) in the wnos.ini.
See if this allows the terminals to relinquish any old TS cal and pickup a new one from your licensing server.
Jun 16, 2009 | WYSE S10 (90210501) Network Terminal
Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
enter
see if anyone else had that same problems
rod
Does other terminal emulation VT220/VT100 work on WYSE?
vt220 on wyse
Sort of but f3 and f4 wont work and f1 would be ctrl + o
Dec 11, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
Wyse wt3235le running on windows 2000 server
OK What ya do is right click the desktop and go down to properties.. open this and there ya should be able to adjust ya resoloution and colour... It's max is 1024 x 768.
Jun 03, 2007 | WYSE Winterm 3235LE Network Terminal
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
WYSE WT3235LE (902032-68) Network Terminal Logo
413 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
