I connect fine but if I leave computer idiol for a bit, I lose the connection and then if I try and reconnect, it says unable to connect. I must shut down totally to log on again
    Scholar:
  • 89 Answers
Please set the printer as default and make sure option printer offline is unchecked.
That should solve the problem
Thank you
gowtam1402@live.com
091-9916828137
Posted on Jan 02, 2011
Keeps saying unable to connect but when im updating the internet connection it says its fine its been like this for weeks now
reset your modem. pull power cord, let 20 seconds lapse, reconnect.
if that doesn't work, go into device manager, open network adapters, delete your device and reboot the computer. windows will install the driver again
Aug 28, 2017 | Internet Computers & Internet
My Sony bravia tv keeps losing connection to the Media server (computer) I can reconnect but it keeps happening randomly daily Please help
Hi there.
I assume that you are connecting wirelessly. The most common problem is that the TV is at the outermost range of the wireless signal from your router/AP. try moving the router/AP closer to the TV. However I would recommend that you use a lan cable rather as this is a more reliable connection. You will also need to check your network settings. To keep the network connection more stable make sure both the TV and media server have static IPs, especially the server.
Feb 03, 2015 | Sony Televison & Video
My hipstreet aurora hs-7dtb6 won't connect to a wifi connection. i have the wifi turned on and n tried connecting it to my home wifi connection but it won't seem to reconnect, it did connect to my wif
If the signal is too weak the connection will be unstable. If you have a lot of wireless routers in your neighborhood it could be affecting your connection. Everything will work fine then the neighbor turns on his equipment and you lose your connection. Try switching the router to a different channel. Try channel 11.
Oct 18, 2014 | Computers & Internet
Unable to connect to the internet Error 106 (net::ERR_INTERNET_DISCONNECTED): The internet connection has been lost. Not actually able to connect to internet. Any ideas?
I have many years experience repairing Canon scanners so here is my suggestion for you.
With Canon scanners this is a common problem but an easy fix. All that is required is that you reboot (restart) your computer to clean out the memory on your computer. Many people leave there computers on all the time and canon scanners tend to leave bits and peicies of images in your memory. A fresh reboot will correct your problem.
I hope this helps you out.
Mar 29, 2011 | Office Equipment & Supplies
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
I use 2wire 1701 HG Gateway for 3 computers. I have been using a Plug and Play network with a password. My primary computer harddrive crashed. I had the drive replaced, but I have been unable to reconnect...
Hello hopefully ican hel solve your issue i have a 2wire modem myself ans have found that 2wire products are very picky. To answer your question for 2wire products when you try to connect wirelessly it wants you to type in the wep key which is the serial number of the product otherwise you are unable to connect. Now as far as losing your password if you are able to get into the 2wire product via browser so you can bring up the main software page you can try to see if you can get too any info that relates to resetting your info like username and password. Otherwise do a search for your product and search forums and you will most likely find someone that has had to recover there info and they will tell you how they do it. Good luck
Feb 23, 2009 | 2wire (1000-400108-001) Router
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Unable to actually connect to the internet?
Have you tried restarting your router? If not, try unplugging the ac power from the router, wait 30 seconds, and plug it back in. That will usually take care of this problem. If that doesn't work, you can try going into "manage your wireless connections", delete your wireless network from the list, then reconnect to your network.
May 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Frequent loss of all operation.
Are you using the client software that came with the unit? If so, do not use it, use the native windows connection client, just use the drivers only.
Also make sure you have it DIRECTLY connected to your computer and not a hub, it seems to work best this way.
Finally under System Manger, make sure it is connected to a USB 2.0 port.
Oct 04, 2007 | EnGenius EUB-362 (EUB362 EXT) Wireless...
jasbo
jasbo
