Question about LG D2526 Gas Dryer
Gasket for dryer lit catcher is coming off - LG D2526 Gas Dryer
  • 1,543 Answers
The gasket on the lint filter is not very important, but you can get a replacement lint filter. There is a screw at the center bottom area of the lint filter area which can catch on the gasket. If you replace it with a shorter screw or remove it, grind it down a bit, and replace it you will help avoid a repeat condition.
Posted on Jan 02, 2011
Comes on, then shuts off after a few minutes. cleaned the lint catcher and the back of dryer.
Depending on the age of the dryer, you could have the main motor going bad. When the motor isn't working properly it will run for a while and then it gets hot and since it has an internal heat safety it shuts off, It won't start again usually for about 1/2 to 3/4 of an hour after it cools back down.
Apr 11, 2015 | Dryers
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FTF2140FS Front Load Washer /...
Dishwasher leaks
At the bottom under the door there is a plastic drip catcher which comes loose from galvanised lip, re attach and that will stop leaks at the bottom, alternatively you adjust the door clip and that will give you a better seal.
Jun 20, 2012 | Computers & Internet
Maytag Bravo is not working
There are many different versions of every dryer, and for us to give you the best possible answer, you will need to find the equipment tag on your unit and give us the model number off of it.
That way we can pull the unit up on our system and give you the most accurate answer to your question.
Dec 14, 2011 | Maytag Dryers
I have heat and movement but it takes hours to dry a load. The last time I noticed that very little lint was in the lint catcher. I moved four months ago and the natural gas person installed it. Maybe it...
The first thing to do is turn on the dryer then go outside and feel how much air and heat is coming out the vent.Your problem sounds like the vent is plugged.
Apr 29, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
An ring fell out of jacket pocket while jacket drying, can see ring when pull out lint catcher. ring located in "dryer pipe" opening next to a rubber gasket in the front of the dryer unit. How...
You will need to remove the hinges, they lift up and out once screws are removed, the the two white plastic pieces with the screws these are for door reversal, then the front panel lifts off. Good Luck Tim
Nov 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer
TURN POWER OFF First remove 2 srews where your lint filter is located.2 lift the top panel of your dryer to do this use a puddy knife and push on the clips located on both sides between top and cabnet.3 remove rear panel on back of dryer 4remove four or five 1/4 inch nut driver screws on blower housing.5 remove obstruction from blower wheel.
Mar 13, 2010 | Whirlpool LER4634J Electric Dryer
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
LG D2526 Gas Dryer Logo
73 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
