Question about GE JKP27 Electric Double Oven
On my GE jkp27w0w2ww i keep having F5 and F3 appear almost everytime i cook. I turn off the oven when it happens and then turn it back on and it usually happens again. Is there something I can do, and what do these errors mean? thanks
  • 1,543 Answers
F3 is usually an oven temp sensor. Replace the sensor. (pencil shapped probe at back top inside oven) It usually can be replaced from inside the oven by gently coaxing the plastic connector through the hole behind the sensor. Sometimes, it is only the plastic plug connecting the sensor. A possible bad connection can be eliminated by usings ceramic (high heat) twist wire connectors to make better connections.
Posted on Jan 02, 2011
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
F3 and F5 errors when first trying to start oven or in the middle of cooking will also get them Mostly F3
F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC).
Aug 12, 2010 | Maytag CWG3100A Gas Single Oven
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
When cooking will get an occasional f2 or f5 error code
HI, This seems to be another ERC issue. the temperature sensory circuit is malfunctioning. the oven will not operate while this condition exist within the ERC. This malfunction will allow your oven to over heat and may cause a fire. The second issue will be that the relay drive circuit is malfunctioning as well. If you cant cancel the error code and continue with normal usage, you will have to replace the ERC once more.
Please rate and god bless:)
Apr 05, 2009 | GE 24" Built-In Single Gas Wall Oven
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Feb 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F3 and F5 signals
could be a probe thats that brass looking rod you see when you open the oven f3 is oven probe code it controls the temp some of them you can take the two screws out on the in side and pull the probe out far enough to get to the connector to change some you have to pull the oven
Sep 10, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
154 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
