I have a M audio Microtrack 24/96 and have had no problems until now. When recording the screen will read media full even though I have little to know files on the device at the time. I tried resetting to the factory settings with no improvement. I now have it set to MP3 and 128 bits. When I check the record time available it says 00:02:06. I am currently using a 128MB card. The unit says 1.9 MB available. Any help???? Thanks.
  • spicyt Jul 09, 2008
    The card I am currently using does not have any files on it. I delete the files once I transfer them onto my computer.
    Thank you I have resolved the problem
  • 983 Answers
I think the card might have got corrupted or may be there is some bad sector formation in it .....
format your card & then have a look at your available memory ........
Posted on Jul 09, 2008
    Genius:
  • 2,035 Answers
This could be the problem with memory card you need you create a
back of the files storied in memory card and then format the card and see if its shows the memory free then store the data back to your card .....
  • 13,433 Answers
Have you tried formating the card?
  • 3 more comments
  • Ekse Jul 09, 2008
    Formatting the Recording Media
    The MicroTrack 24/96 records directly to CompactFlash cards or Microdrives. In both cases, these mediums must be formatted before they can be used. The MicroTrack 24/96 can format the media with the following procedure:
    NOTE: Formatting a CompactFlash card or Microdrive will erase all of its data. Thus, formatting can be used as a method for deleting the entire contents of a card or drive.
    1. Insert your media, either a CompactFlash card or Microdrive, into the MicroTrack 24/96. The unit will reboot.
    2. After the MicroTrack 24/96 has rebooted, press down on the [NAV] wheel until “System” is selected and press in on the [NAV] wheel.
    3. Press down on the [NAV] wheel until “Format Media” is selected, then press in on the [NAV] wheel.
    4. The screen will show “Format Media.” Press in on the [NAV] wheel to continue.
    5. When the process is finished, “Format complete!” will be shown on the display. Press the [MENU] key twice to return to the main menu.
  • Ekse Jul 09, 2008
  • Ekse Jul 09, 2008
    try the format and report back.
    Note that reposting the problem rejects my support
    comment / reply will send me a message
    Thanks,
    Ekse
  • Ekse Jul 09, 2008
    please read this page, its about the problem you are faceing
    http://www.m-audio.com/index.php?do=supp...
  • Ekse Jul 09, 2008
    Great that the problem is now solved, please press accept on my solution otherwise I will not be credited.
M Audio Microtrack 24/96 MP3 recorder battery short life. How to change battery? No screws in body.
I had this issue and had to return the unit to the manufacturer for repair.
Nov 22, 2010 | M-Audio MicroTrack 24/96
Won't record
I suggest that you to select Reset to Factory Defaults in the System menu to soft reset reset the unit or by pressing Delete and the power button and holding them down to hard reset. Good luck!
Dec 14, 2007 | M-Audio MicroTrack 24/96
Hello, My M-Audio microtrack 24/96 battery runs out so fast. What do I do? Is it time to change it? Is getting a new battery expensive? Do I not charge it long enough? I let it charge for at least 4 hours...
Similar problem to mine, and until I get my question answered, I can only propose a temporary solution.
Get a USB cable that fits the bottom small USB socket on your M-Audio Microtrack, but with a standard USB plug on the other end. Such a cable should have come with your Microtrack to begin with.
Replacement cables can be found at Best Buy, Radio Shack or most electronics stores or department stores. If the original cable is broken, please save it for reference to make sure you are getting the exact same type connectors when getting your replacement.
As I learned the hard way, not all small USB connectors are the same size, but APPEAR the same.
So, what are you connecting on the standard USB end?
A battery.
That's right, a rechargeable battery that features a power-only 5 volt USB receptacle. This will function as your A/C power adaptor does, only on the go.
The external rechargeable battery I use is a Black and Decker "Power to Go" unit that measures approx. 5 1/2"L X 3"W X 1" D.
It has both a low-draw two-prong AC (yes, it has an inverter and I never use it) and the desired 5V USB receptacle. You may find a better solution WITHOUT that A/C inverter. Just ask around for a rechargeable NmHh (better than NiCad) battery with a standard USB receptacle.
If the Microtrack's power is off when it is connected to the 5V power source (be it A/C power adaptor OR my proposed external battery), it will go into charge mode. With a fair amount of charge, remove the external power, and it boots up into operation. Then, re-connect the external power and your Microtrack is running and recording for a considerable longer time, depending on the charge and condition of your external battery.
Now, if one observes the LCD screen while running off of external power, the upper right corner box indicating the internal battery's charge shows "CHG" instead of the black square (Full charge) or half of the box in the form of a triagle (half charge) or any variation thereof as normaly indicated.
Someone might say, "But I don't want to have to carry around all this extra stuff! I want my old battery life back!"
Well, that's precisely how I feel as well.
But until you get your original lithium ion battery replaced (and at what cost for parts and labor?), you have to ask yourself if being an original condition purist is serving your situation well, or if this proposed add-on can get you by in the meantime.
Take care.
JJM
May 18, 2010 | M-Audio MicroTrack 24/96
Cracked lcd screen
You can more than likely. Look it up on the internet, there should be a diagram somewhere showing you how to take it apart.
Nov 19, 2009 | M-Audio MicroTrack 24/96 Professional...
Microtrack screen is on and frozen
I was able to clear the same issue by removing the CF memory and erasing it using a USB card reader connected to my PC. I erased all the files and reinstalled the card in the Microtrack. Works fine now, must have been a corrupted file even though it only contained two mp3s I had recorded earlier.
Dec 19, 2008 | M-Audio MicroTrack 24/96
MicroTrack Levels are off balance
That sounds like a hardware problem requiring a service. The front-case buttons are sensitive to pressure and I suspect that they go bad if stored where something is pressing against them.
May 28, 2008 | M-Audio MicroTrack 24/96
Freezes while recording
I'm been searching for slutions to this as well - It's happened to me numerous times, so much so, I've almost thrown it on the ground to see how many pieces I can break it into...
Apr 11, 2008 | M-Audio MicroTrack 24/96
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Nov 07, 2007 | M-Audio MicroTrack 24/96
 Grubhead
Grubhead
