Question about BenQ W10000 Projector
The projector will turn on normally, but after about 20 seconds the screen will go black and the "temp" and "lamp" alarm lights will flash on and off. I've changed the filter and we very recently changed the lamp (maybe 150 hours of use).
    Guru:
  • 452 Answers
If you are replacing the lamp by yourself, and if you are touching the lamp body with your fingers, the lamp will be damadged fastly; because the lamp is sensible. the temperature of the lamp increase abnormally so the message 'temp' and 'lamp' increase. to solve the problem you need to replace a new lamp, but you have to install it at the BenQ service it's free.
Posted on Jan 02, 2011
  • polytek Jan 03, 2011
    if you are replacing the lamp by yourself, and if you are touching the lamp body with your fingers, the lamp will be damadged fastly; because the lamp is sensible. the temperature of the lamp increase abnormally so the message 'temp' and 'lamp' appears. to solve the problem you need to replace a new lamp, but you have to install it at the BenQ service it's free.
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Dec 05, 2016 | Office Equipment & Supplies
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Press the power button to switch it on, the sony logo lights up and it switches on as per normal operation, it then switches off after a few seconds and the temp/fan light flashes
hi,
may be your projectors lamp colling fan have some problem. may be it is get jammed due to dust or it may be faulty. without fan the lamp will get over heated. that's why the temp/ fan lights flashes.
jus check it . need further help feel free to contact.
ok
Dec 20, 2010 | Sony Projector Lamp for VPL-HS51
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
Sanyo PLC-XP55 "new" both temp and ready lights flash
One of the common problems on this and the 56 model is the exhaust cooling fan, the reason being that due to the heat given off from the lamp assembly the bearings dry up, even if they dont fail but go stiff, this also causes problems because inside the fan it is fitted like most of them now with a rotataion speed sensor and the system control monitors the pulse reference.If this changes and is not upto speed to keep the lamp cool enough the internal heat sensor detects this and the unit locks up into protection mode to protect the lamp assembly from getting too hot or even exploding.Kind regards John Williams www.jvsvisual.com
May 10, 2009 | Sanyo PLC-XP55L Multimedia Projector
Unit turns on for 20-30 seconds then powers off.....Please Help
it is the ballast issue,u can try one of the equivalent ones or just try & rework on the old one, perhaps one of the mosfets is leaky!!!!!!!!
Feb 06, 2009 | HP Digital Projector Vp6110 Multimedia...
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
BenQ W10000 Projector Logo
301 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
