Question about Bosch Exxcel WVT3250 Front Load Washer / Dryer
Bosch Exxcel front-loading washer dryer drum does not get hot enough to dry clothes. Sometimes, the dryer stops when there are 23 minutes remaining (always 23). We simply turn off machine and then start the drying programme again. It sometimes flashes F19 and will not start drying; by turning off the machine, removing the clothes, returning them to the machine, and then starting a new dry cycle, it will then start up. The main problem is that the drum only barely gets warm--not hot like it used to be--and takes several hours to dry a half load. We only put half loads in the dryer. We had an engineer out twice and he replaced two heating parts--that I think monitor the heater temp. After the second heating-part replacement, the drum was hotter during drying but then returned to only mild heat and taking forever.
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
SOURCE: bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
Posted on Jun 11, 2008
jason0110
  • 66 Answers
SOURCE: We have a Bosch Exxcel
would try cleaning your pump and sump as when its draining without the force of the spin the pump is idle but with the force when you put on other programs ie the spin this will push the water through the pump hope this helps
Posted on Jun 22, 2008
  • 5 Answers
SOURCE: Bosch washing machine not drawing water
you probably have the "burst free" hoses, this machine draws water too fast so the hoses think they burst, change the hoses to the original or get new ones that aren't burst free and this should solve your problem
Posted on May 04, 2009
barkencoa
  • 3463 Answers
SOURCE: bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Posted on Jan 07, 2010
My Bosch Classixx washer dryer has stopped drying and the clothes come out steaming hot and steam escapes from the powder drawer during the drying cycle. I have had an engineer out and he says the airflow...
if you have a very large load of clothes in the machine on the dry cycle, what tends to happen is that the clothes are not flapping around in the drum loosely but they are going around the drum in a big mass, with the result that they just get very very hot and steam will escape out the soapbox draw. When this happens, heater unit that becomes overheated ant the thermostats will eventualy cut out resulting in cold air being circulated instead of hot. You will need to have them replaced again. when replaced, put on a drycycle with only a few garments in the machine and you will see a big difference in it perfomance. washer/dryers are not very effective on the drying cycles with a full washload.
if you need any more help, you may email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WVF 2402 Front Load...
Not drying correctly leaving residue on clothes
its uncommon for elect dryer to put res on clothes your vent must be stopped up
Nov 17, 2009 | Bosch Exxcel WVT3250 Front Load Washer /...
Drying cycle working but not drying clothes
First clean filter for lint - next be sure the temp sensor at blower if free of lint - next, in the heater contrl unit, two solinods contrl the heating process - I hope it's the first two ideas - Try it - Good luck
Oct 15, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
Blue stains on laundry
I was talking toa repairmain about which washer/dryer to get and he mentioned that the Bosch can stain clothing blue. I don't know anything else about why...but I'd contact my Bosch dealer.
Jul 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Maxx WFL 2850 - the drum will not turn around
hi there sounds like a simple case of worn carbons cost about a £10
Jan 11, 2008 | Bosch Exxcel WVT 2850 Front Load Washer /...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Bosch Exxcel WVT3250 Front Load Washer / Dryer Logo
60 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
