Question about Kenwood DPX303 CD receiver
My unit went into protect mode randomly while i was blasting some music and now i can't figure out how to turn the protect mode off
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
You probably blew either a speaker or the output ic in the radio.
Posted on Jan 03, 2011
Hi;my Yamaha receiver RX-V 373 will not turn on. No power. No display. It may be that the unit went into protection mode. Can anyone there, help me, restart my unit back to factory condition?
If you have power it should click before protection mode and have a light showing it's in protection mode.
After the transformer there's some resistors that have failed if it's in protection mode normally it's one or two that have failed, you can get the reading of what they should be by testing them
Apr 17, 2016 | Yamaha Audio Players & Recorders
How do i stop a power acoustik pd-450 from randomly shutting off? Ive checked connections and wiring all is good, the power supply is good as well
how random is it? Make sure the radio is grounded properly. Look in the pin outs in the harness and make sure there is a ground there. Also, you may have 1, 2, 3, or 4 bad speakers. A short in any one speaker will send the radio in protect mode. Also, If your radio is seeing less than something around a 3ohm load (technically 4) it will protect itself as well.
Dec 26, 2014 | Power Acoustik Car Audio & Video
Is there a way to put the device on shuffle mode?
  • There is a random setting rather than a shuffle mode. Same thing just a different name.
  • While in the play mode menu press "PREV/NEXT" to select the desired repeat mode ie.
  • Normal, Repeat One, Repeat All, Random, Random All, Preview.
  • You want to choose "Random" or Random All" depending on
  • Random - All music is played randomly until all songs have been heard.
  • Random All - All music will play randomly until you turn the MP3 player off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Curtis MPS2015 MP3 Player
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
How do I set it to play random songs?
While a file is playing you can enter the Music Submenu by pressing the “M” button briefly. The Music Submenu allows you to adjust your repeat mode, amongst other things.
The Repeat Menu allows you to set your repeat mode. Choose from Normal, Repeat One, Folder, Repeat folder, Repeat all, Random, and Intro.
Choose Random.
Here is an online version of the manual, incase you have any other problems you want to read about. http://www.eclipsemp3.com/CLD2manual.pdf
Feb 27, 2010 | Eclipse CLD2 MP3 Player
MY Fender Passport P250 went into protect mode. I changed the FUSE at the power supply with a new fuse. Still it is in Protect mode. How to fix this
This needs to go to the repair shop. The protect mode is turned on when either the power supply has a problem or one or both power amplifiers have a problem. These are often blown components.
These units are HARD to work on. To open you have to first remove then front panel before you can remove the back panel that has the power supply and power amps/heat sinks.
Compare repairs of these units to working under an automobile dashboard!
Hint: On startup, use a series 150 wat lamp to limit current while repairing. SInce these use a switching supply operating off the input line, use an isolation transformer for personal safety.
Oct 04, 2009 | Fender Passport Deluxe 500watt Sound...
My Zen is stuck on DJ mode and Shuffle mode. HELP!
Hold down the back button until a little gray screen appears. Then scroll down to Play Mode and select normal.
Jul 03, 2009 | Creative Labs Creative Technology Zen MP3...
Protection mode
The protect mode with nothing connected indicates that the output transistors for one or more channels are shorted. These will need to be checked and replaced. This is a simple repair for an experienced audio shop, Figure about $10 for each output transistor and add in another $10-$15 for misc parts that may also be smoked.
Dan
Mar 18, 2009 | Denon AVR-3600
I have a jvc stereo and its stopped playing music and went into protect mode what does that mean? is there something that i can do for that with out paying lots of money to get it fixed and just do it my...
Usually "protect" mode means it has either
1. Overheated (a thermistor on/near the cooling fins for the audio output transisitors has indicated that the machine is running too hot). This is usually solved by turning the unit off for 30 min.
or
2. Some circuit inside the unit has indicated an error condition, turning your stereo into a doorstop.
Thanks,
Rob
Feb 27, 2009 | Audio Players & Recorders
Flashing Protect light
what are u using to play music??
Feb 12, 2008 | Infinity Reference 5350a Car Audio...
Kenwood DPX303 CD receiver Logo
168 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
