Question about Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover
Tank will not turn on when sink hot water is turned on
    Problem Solver:
  • 4 Answers
Do other faucets in the house work ok? if so the kitchen faucet may not be creating enough water flow to trigger the noritz. The Noritz have a flow meter inside of them (depending on the year they where made, older units require 3/4 GPM, newer models require 1/2 GPM). If the kitchen faucet is not turning on the hot water, you can check the angle stop and make sure it is open all the way. Also check the aerator on the faucet to make sure it is not plugged and restricting the flow.
Posted on Apr 05, 2011
I have a new AO Smith Electric Hot Water heater. When I turn on the water, at any of my sinks, or my shower, it's very hot for a minute, then it turns lukewarm.
Your water heater may not have been installed correctly. You should get hot water shortly after you turn on the faucet. There may be a defective heating element or temperature controller. Also, the 50 gallon tank may be too large for your application.
Oct 10, 2016 | Water Water Heaters
Hot water heater has hot in tank but dose not come out of hot water line on tank
most electric hot water systems use a heat transfer process where the element is in one tank and the house water is in another
the house water is what is being drawn off when you turn on a tap
there is a regulator valve at the top of the tank with a small lever that you open up to let water in and air out of the system
another point is that there may be a hot/cold mixer on the hot water outlet which limits the temperature of hot water to prevent scalding injuries in the bath and shower or sink
If you have one fitted they are known to malfunction and cut the hot water temperature down as, they mix too much cold water into the hot water pipe.
have a plumber check it out
Jun 13, 2015 | Water Water Heaters
How to get hot water to the sink
did you turn on the hot water heater? water pump? limited,, and there is a nice dutchmen owners dot org site which I belong to,, alot of smart guys. good luck
Jan 26, 2015 | Dutchmen 2013 Coleman Explorer CTU271RB
Have a 2005 coach w/Atwood DSI-RV 6 gal water heater. Gas lights, heater fires and gets hot, but doesn't transfer the hot water through the lines to the sink faucets. jwmystery@aol.com
You need to check by-pass valve(s) on back of tank for proper position. You need cold open going in to bottom tank fitting, and hot open at top. If any valves in between those 2 lines via "T"'s, turn them to off position.
Oct 29, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
The hot water tap was loose upstairs, the repair man came and fixed it but now i dont have any hot water, is there anything i can try, or will i have to call a repair man out again !
He probably turned off the hot water at the water tank so that he could disassemble the faucet to repair it, then forgot to turn the water back on. If you have no water at all out of any hot-water tap, then you will find a closed water valve at the hot water tank. If you have hot water at all taps except the one he repaired, then you need to open the valve located under the sink.
Oct 21, 2010 | Water Heaters
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Temp. too hot .Where can i find the temp. control? thanks
There isn't a temp control on water entering a household dishwasher. The water temp is controled by the actual water heater at the residence. Is is hooked to the hot water side of your nearest sink. Good Luck
Dave
Aug 19, 2009 | Dishwashers
On demand, tank less water heater
THE WATER IS RECIRCULATING IN THE UNIT. MAYBE CAUSED BY THE ACID. TRY INSTALLING A BACK FLOW PREVENTER
Oct 25, 2008 | Water Heaters
Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover Logo
160 people viewed this question
Top Noritz Plumbing Experts
Kyocera HP Expert
paulcarew
Muzammil Razzaq
Muzammil Razzaq
Are you a Noritz Plumbing Expert? Answer questions, earn points and help others
