Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC. when I connect it the drive light starts to blink and I hear a continuous beep form the laptop.
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on Jan 02, 2011
I have a WD Passport External Drive. (WD1600ME-01) I know it works but all the wires I have that fits the Drive don't seem to work. When I connect the wires, I can hear the Drive go on and shortly aft
You may first want to try disconnecting any other USB devices, to guarantee that the drive is the only power-drawing device. Drives typically need all 500 mA that a USB port normally provides.
Cables do wear out, especially those handled often. Mini-USB cables are pretty common and can easily be replaced.
WD Support Downloads My Passport My Passport Essential
Dec 02, 2014 | Passport Computers & Internet
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 28, 2012 | Western Digital WD Passport 250GB Portable...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
My Passport Drive is no longer recognized by windows
Check to see if the drive is available in disk management, if so and it's got a blue bar at the bottom, try changing the drive letter. If not, try the following:
Normally with the passport drives, you receive a shorter USB cable (this is because the drive relies on power from the PC, which your normal length USB cannot offer sufficiently. If you are using a short cable, try connecting the drive to the back of your desktop PC, this generates more power than the ports on the front (the ports on the front are actually hubs). If none of these options work try it on another PC, using the steps above.
If you still have an issue, the drive has most likely failed and you will need to get data recovery done to retrieve your data. If you do so, contact samsung for warranty information, so that your warranty doesn't become void.
Jan 24, 2010 | Samsung Portable 120GB USB 2.0 External...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
3,084 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
