Question about Cameras
HOW DO I FORMAT MY LEXAR SDHC? i PUT IT IN MY CAMERA AND IT SAYS TO FORMAT. I SAY CONTINUE AND THEN IT GOES INTO THIS LOOP. ''NEEDS TO BE FORMATTED.''
  • Cameras Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Jan 02, 2011
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I have akodak easyshare c633 camera have had it for bout 3 years with no problems.Ive decided to purchase a new memory card for it instead of just putting prints on a cd at walmart.The full card is a...
Your camera cannot use SDHC cards....only SD. If you copy and paste this address into your browser, you can download a copy of the owner's manual. http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00634/C633_GLB_en.pdf
Dec 21, 2010 | Kodak EasyShare C633 Digital Camera
Put new lexar sdhc 4GB memory card in my canon sd550 and get card locked. moved tab to both positions but same error message. do i need to return this card?
see if their might be some photos or file saved that you may have edited on the card maybe Microsoft visual studio's photo shop save to hard drive. delete with photo software and format put in camera format again. if it works with computer and not with the camera not compatible try another card
Jul 04, 2010 | Lexar Professional High-Speed 2GB Secure...
WORKING CAMERA WONT TAKE MEMORY CARD
It's possible the camera won't take an sdhc card. Or maybe you just need to move the slide switch on the side of the card to unlocked or that you need to format the card in the camera.
Dec 26, 2009 | Cameras
I have a NV10, it will not format the lexar 4GB SDHC memory card I bought, all it says is format error
The NV10 will not accept SDHC type memory cards. The largest card you will find it takes is a 2GB card of the SD type (not SDHC). The camera is not SDHC compliant, unfortunately. If you can return the 4GB Lexar, swap it for a 2GB of the non-SDHC variety. If this answers your question fully, please rate the solution accordingly. Thanks
Nov 07, 2009 | Samsung NV10 Digital Camera
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
try using your camera as a card reader and connecting it to the computer. see if it will open up as an external storage device and try formatting through windows. if that doesn't work, try an external card reader. note that some newer laptops will have a sd slot. if not this, then it might be a faulty card.
Oct 13, 2009 | Cameras
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
Cameras Logo
237 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
