I have a Philips LCD TV Model 23PF5320/28. How can I connect a Blu Ray DVD player to it. I have an HDMI cord attached to the DVD player, but there is nowhere to plug the other end of the cord into the television. What do I need to do in order to be able to use HDMI? Thanks for your help.
    Brigadier General:
  • 8,909 Answers
The only way to connect via HDMI is to have an HDMI socket on your tv. You will have to use a standard video lead instead. It will still give exceptional picture quality it will use three wires instead of one.
The DVD player should have phono type sockets on the back or scart, to match the input sockets on your tv.
Hope that helps.
Posted on Jan 02, 2011
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
Cannot connect Philips DVD Model 2850/12 player to he above tv
I see no TV but there should be either an HDMI pjack or RCA jacks to plug the player in with .
Oct 13, 2015 | Philips Televison & Video
Philips quadrasurf TV
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
Sep 08, 2014 | Philips 40MF430B/F7 model Magnavox LCD TV,...
No audio
You have to have the cable with three colors, yellow is video, white is one side stereo and red is other side. Plug into av on back of tv then select the av
Dec 25, 2013 | Philips Blu-ray Disc Player with Wi-Fi -...
Problem connection philips blu ray player to Apex LD4088 with HDMI cable
I am having the same issue with this. Did you find a solution.
Dec 31, 2011 | Apex Digital LD4088 LCD TV
Philips DVD connected to SET TOP Box with W/R/Y cables. DVD connected to Philips TV via HDMI. Turn on DVD and TV screen says "Format Not Supported"? Help
Change the video resolution format from HDMI set up menu. This way you can know that if Player and TV supports/displays any one or some of the resolutions and if you can get a video on TV.
Jan 05, 2010 | Philips DVP3982 DVD Player
We have a philips up-grader dvd player and get color distortion
I would try hooking something else up to your tv that is hdmi compatible. If your tv looks fine, then you know it would be the dvd player. If it's the dvd player, then I would suggest getting a different brand completely. I have had alot of bad experiences myself and other people as well when it comes to the philips brand
Apr 07, 2009 | Philips DVP3960
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
