Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
I have a bosch WFD 2460 electronic washing machine, after ive done a wash the drum fills up with water and has flooded my kitchen. so i now turn the water off at the mains to stop this but would like to know why it's doing it! and today it didnt even empty when id done some washing so some wringing wet clothes!
  • 1462 Answers
SOURCE: WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Posted on Jul 23, 2008
saumyar
  • 174 Answers
SOURCE: How do I change the heating element on a Bosch wfd
go through this link to know your product better before fixing it:
http://www1.epinions.com/review/Bosch_WFR_2460_Axxis_Washer/content_84131024516
Posted on Jun 08, 2009
  • 157 Answers
SOURCE: bosch 2460 won't spin
only brushes in motor ,he taking the mikey motor only 236.00 from bosch
Posted on Jun 30, 2009
  • 715 Answers
SOURCE: my machine is about 7 years old but now is only
bad water control valve
Posted on Nov 13, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
I have a bosch wfd 2473 washing machine it will not pump or spin, i have removed the water by releasing the filter there is nothing within the filter and the pump spins quite freely .i could not syphon the...
bosch wfd 2473 washing machine it will not pump or spin This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 27, 2012 | Washing Machines
My bosch wfd 2460 won't spin and drain
Needs to drain 1st then spins after this if not draining .Clean filter take out small hose next to filter to assist in removing water 1st if drum quite full ..Then clean filter this should cure,,,
Nov 16, 2009 | Washing Machines
Bosch 2460 won't spin
Jun 30, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
How do I change the heating element on a Bosch wfd 2460?
Jun 08, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Inner drum of my 7 year old washer WFD 2460 rattles on spin and seems unsupported. The rubber surround is intact, is it the only means to support the drum? Thanks. J.Reeve
Hi there!
I would say it is the rear drum bearing which needs replacement. This is what supports the load of the entire drum. The seal is just a water seal.
The good news is that it's a bosch, and replacements are easily available. You are lucky to get 7 years use without problems. Cheaper models give up after 12 months!
Check online for spares under the model number, or have it replacd by a local technician. It is the main drum bearing you need.
If this assists to a solution, Please take a moment to rate as fixya! Thanks.
Jun 18, 2008 | Bosch Washing Machines
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
115 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
