Question about Car Audio & Video
Why are my brake lights not working on my 1997 chrsler concorde? The fuse and light bulbs are good. I've heard this may be the brake light switch. If so, where is this located?
  • 883 Answers
Switch is at top of brake pedal. wire colors are PINK/DK BLUE and WHT/TAN. check to see it is actually contacting when pedal is depressed.
Posted on Jul 09, 2008
1997 olds cutless brake lights will not work. bulbs, fuse and switch are good
Its a faulty turn signal switch.Try this,push down and hold brake pedal while pushing on the hazard switch and if the brake lights come on then replace the signal switch.
Jan 29, 2012 | 1997 Oldsmobile Cutlass Supreme
The trunklight bulb doesn't light in my 1997 Chrysler Concorde LX1; when I put in a bulb, it lights up for a second, then blows a fuse. What could be the problem?
There is a short in the bulb holder and so when the lamp is switched the shorting blows a fuse. If there is no fuse blow after the bulb is removed then there is some shorrt within the bulb holder which must be replaced. Also check the rating of the fuse to match the rating o of the circuit.
Sep 30, 2011 | 1997 Chrysler Concorde
I have changed my brake switch, fuses, and bulbs in my 1997 chevy lumina and the brake lights still will not work at all, my signal lights only work. What could be the problem?
here is howw it goes, the power from the fuse goes to the brake switch then to the signal light switch and from there to the rear lights, test for signal from the brake switch to the turn signal, if good the signal switch is bad
Apr 13, 2011 | 1997 Chevrolet Lumina
Center high-mounted stoplight is not working? Where is the relay?
If the two rear brake light are working on each side, then fuse and relay are good, check the bulb.
Jul 08, 2010 | 1997 Chevrolet Blazer
Brake lights dont work,fuse good ,bulbs good,third light works
The third brake light switch works off a module for it is a sealed unit with a inverter that takes 12 volts beefing the voltage to 110 volts for the light emitting diode lights in it. It these terms you will need a new brake light switch located by the brake pedal
Apr 20, 2010 | 1997 GMC Jimmy
My tail lights are NOT working but my brake lights
bulbs are good the the headlamp switch is bad. the brake light switch is good if those light up
Mar 02, 2010 | 1997 Ford Taurus
1997 monte carlo. 3rd brake light works, but tail lamp brake lights do not.
The 3rd brake light working does reveal that the fuse is good, and the brake switch is good. Check the bulbs, sockets, and the wiring between the brake lights
Jul 04, 2009 | 1997 Chevrolet Monte Carlo
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
