Question about Whirlpool GEW9250 Electric Dryer
Hello, I have a duet whirlpool dryer thats about 2 to 3 yrs old and it wont come on. Ive checked all the wires with a ohm meter and everything checked good. when I open the door the inside light comes on. Got no front top panel lights and wont start. It worked fine the last time I used it and then the next day I put a load in it wouldnt come on. Thats when I checked the wires. I unplugged for serveral hrs and when I plugged it back up, it worked. Now its not. Can you help, please? Thanks, Merri
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
I suspect the thermal fuse may be open which will cause the dryer to not start. It is located and accessed by removing the lower panel. The fuse is available at http://aplusapplianceparts.com/searchquick-submit.sc?keywords=3392519
and is easily replaced. There is a picture of the part at above link for easy identification. Use coupon code 1050 for a discount on your order!
Posted on Jan 02, 2011
Fault code 8 on a whirlpool duet front load electric dryer GEW9200LW1
Could be bad heating element, bad high limit thermostat or bad cycling thermostat. All of which can be ohmed out with a standard ohm meter. If you replace one I would replace all of them, if you don't you will be going back in there later and replacing another one of those parts
Jan 16, 2017 | Whirlpool Dryers
My whirlpool duet dryer periodically has no signs of power. No lights, no digital lit numbers, no nothing. After a few hours it suddenly starts working. Any ideas?
Intermitent problems are the greatest challenge. I would check for a fuse usually located inside the back large back cover of the dryer. A fuse can be checked with a multi-meter with the ohm meter and when one touches the probes to both sides of a fuse, the ohm meter should go to zero. A fuse that has failed will not go to zero. The fact that the problem is intermitent leads me to believe that the fuse may be about to fail or that a wire to one side of the fuse may have come loose. Remember that a dryer does vibrate and wires can come loose in time. Be sure to unplug the dryer before checking the fuse. Whirlpool and Kenmore are I believe made by Whirlpool. Check Searspartsdirect.com for the needed fuse. Have the Model # and serial number handy to facilitate the process. Good Luck
Aug 05, 2014 | Dryers
I have a whirlpool duet wed9400sw2 dryer it has power but wont start?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Jun 25, 2014 | Kenmore Dryers
The dryer is not heating
Hello there here is a list of things to check
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
Jan 09, 2010 | Dryers
Whirlpool duet dryer model GGW92006W0 wont heat up.
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Nov 18, 2009 | Dryers
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool electrc dryer,2 years old,no heat.model # LER8648PG1
quick check is take off back. get ohm meter and ohm the heat coils on the heater. second check is on the vent lint sensor. just inside the vent opening. disconnect wires and ohm it. If either has an open circuit, no heat. these are the two most common problems
DAvid
May 22, 2009 | Dryers
Whirlpool duet dryer model # GEW9200LW1 suddenly quit working. We think it is the fuses, where do we find them and how do we check to see if they are good?
you will need an OHM meter to check continuity. or you can jump the wires but you must replace a bad one for its a huge safety hazzard. (you can slide the 2 terminals together if you have them upsidedown from each other.
the thermal fuse is located right on top of the blower housing.
to get to it remove the lower pannel 3 1/4 inch screews you will see 2 wires going into a white plastic almost football looking peice ontop of the blower housing. it is also held in with 2 1/4 inch screews. thats the termal fuse if nothing turns on or work thats the most common problem. if you jump it and the dryer works then replace the t-fuse Part # 3392519 $20.95
Joe Johnson
Appliance Doctor
Marshalltown Iowa
Jan 10, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet Dryer - Working but no heat
i need help fixing my 5 year old dryer. whirlpool duet model GEW9200LW1. I have replaced the thermistor. I tested (with an ohm meter) the heating coil, thermal fuse, high limit thermostat, & heating element and they were all fine. I replaced the electronic control assembly and the user interface. THE DRYER STILL WONT HEAT.
Then it occurred to me that the sensor may not allow the dryer to heat if its not sensing wet. Could this be true? Have I been trouble shooting this wrong?
Help me.
Dec 16, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
