Question about Garden
I have a poulan bvm200vs leaf blower and it also leaks gas while running and for a short time after it is shut off unless you bleed pressure off from tank. can't find where leak is coming from. can you help? thanks
  • 323 Answers
SOURCE: I tipped my poulan riding mower up from the right to check belt
If you remove the plug(s) so that the oil all drains back down, and some will drain back out of the muffler, it should start. But give a at least one day, maybe two. You may still have to put new plug(s) in it after it's gone. Check the fuel filter and see if you can see oil in it.
Take off the air cleaner when you get ready to start it and spray just a little starting fluid in the carb, Don't choke it. It will run rough and smoke like crazy, but after it runs a while it should be fine. It make take a few starts before it continues to run. At first it may run just on the starting fluid, but once the plugs fire up enough to burn the oil out it should run on its own.
Be sure and check the oil and if it seems like the slightest amount of gas in it, change the oil and filter.
Let us know how it comes out!
Sirwriter
Posted on May 16, 2009
SOURCE: Just bought a used leaf blower, homelite, gas leaks out of the gas tank, where the gas tube fits into it.
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
Posted on May 29, 2009
spekgt
  • 60 Answers
SOURCE: Husqvarna GTH2250B riding mower leaking gas tank
Hi there
The tank on that machine is a Husqvarna tank . The part # is 532 15 13-46 and you can get it @ your local Husqvarna dealer. To find a dealer near you just check the link below
http://www.husqvarna.com/us/homeowner/support/dealer-locator/ . About any recall on the tank you probably have to contact Husqvarna direct . Use "contact" on the Husqvarna site .
Hope this help
Posted on Sep 03, 2009
  • 124 Answers
SOURCE: replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: gas leak in sears lawn tarctor model
You will have to remove the seat and then the platform where the seat mounts, this will give you good access to the fuel tank. I know it looks like a daunting job but there are only about 8 or 10 bolts that hold the entire thing on and if you look it over before you start to find all the bolts, you can have it off it 10 or 15 minutes.
You can go here if the link works and see an exploded view of it:
http://www.searspartsdirect.com
Type in your model number then select Chassis and Enclosures
Posted on Sep 15, 2009
Testimonial: "very helpful answer "
Leaf blower starts and runs for about a minute, but then sputters and dies when i give it gas...any thoughts?
Very small jets in carb , needs taking apart and blowing out with a compressor , just by mouth isn't strong enough .
Jan 24, 2015 | Poulan Garden
Can I get a trouble shooting guide for a Poulan Pro leaf blower bvm200vs
the owners manual, available online has some trouble shooting tips...
Oct 18, 2014 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
Whats the compression rating of bvm200vs blower
6 or 7 to 1 I think. If you have a compression gauge see if it is around 90-105 psi.
Jun 18, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What oil goes in crankcase of poulan leaf blower
Are you sure this is a four stroke engine, i thought all the small blowers were two strokes in which case there is no oil in the crankcase, the lubrication is mixed with the fuel
Feb 19, 2013 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
Poula pro bvm200vs/ 25cc won't start
i have a polan bvm200vs. that wont starits got the main 3 gas spark and compresion i even change the gas in it and still noyhing
Oct 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
