Question about GE Profile JTP18 Electric Single Oven
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
  • Cathy Fleming Jul 03, 2013
    mine if the built in model - any suggestions if I can fix the sensor myself?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Jan 02, 2011
  • 1,543 Answers
F3 is usually an oven temp sensor. Replace the sensor. (pencil shapped probe at back top inside oven) It usually can be replaced from inside the oven by gently coaxing the plastic connector through the hole behind the sensor. Sometimes, it is only the plastic plug connecting the sensor. A possible bad connection can be eliminated by usings ceramic (high heat) twist wire connectors to make better connections.
  • 1,531 Answers
This is a open oven temp sensor circuit.Check the oven temp probe it should read 100 ohms at room temp.Or if you can not check the ohms then replace the oven probe.
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: GE Profile-electric oven
Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
Posted on Sep 19, 2006
SOURCE: f3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Posted on Mar 12, 2007
aborcass
  • 2651 Answers
SOURCE: F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
What is an F3 message on a GE Profile JKP18 oven ?
Hi jmjburns,
The F3 fault code description is an open or shorted oven temperature sensor. Please check the sensor harness and harness connection between oven sensor and oven control. If the wiring is ok and still encountering the same error, please replace the temperature sensor.
Hope it helps.
Thank you for using FixYa.
Nov 10, 2010 | GE Profile JKP18 Electric Single Oven
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
Have -F3- on the screen and nothing works
**FIRST; shut off the breaker or unplug the unit before going any further please**
"F3" on most GE ovens describes a fault with the oven sensor or sensor circuit. Ohm out the sensor. It should read approx.1100ohms. @ room temperature.
The other possible faults are a bad solder on the control, a pinched or severed wire from control to sensor.
Having said all that, 99% of the time, its' a sensor. most common GE sensor is part # wb21x5301.
hope that helps
good luck
Oct 01, 2009 | GE Profile Advantium SCB2001KSS Stainless...
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Apr 22, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile Oven Model JKP13G0V1BB
f3 is a bad oven sensor, two screws will remove it in the upper left or right hand side of inner cavity.thin metal shaft protuding maybe 3inches or so.
Mar 23, 2008 | GE Profile JTP18 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
F3 code
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
Sep 19, 2006 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
547 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
