Question about Neff 24 in. S5457X0GB Built-in Dishwasher
4 years old with light use.fills with water.house fuse blows.reset house fuse & blows every time the door is closed.have striped to a point & can run the mashine if i disconnect the red wire to the heater element.it then fills & will not move on & obviously will not heat.heater element is expensive & looks time consuming to replace. ntc,thermostat,programmer or element ? some ideas or tests please
4 Suggested Answers
  • 7 Answers
SOURCE: NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Posted on Oct 09, 2008
wbwill
  • 68 Answers
SOURCE: NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Posted on Nov 05, 2008
SOURCE: Dishwasher not washing very well
hi i have a neff s5433xogb/13 and the top arm does not rotate,i have checked for any blockage and cleaned it all out any ideas please
Posted on Jan 10, 2011
Asea Cylinda 1400 dishwasher not filling. Keeps waiting for water to fill. Continues normally if manually add water. Tap is on and water available.
The incoming water valve is faulty. Look at the back of the machine where the hose connection runs into the machine, there should be a solenoid operated water valve there. Check that out or replace it.
Dec 05, 2014 | Dishwashers
Machine won't start, lights are all on and ready to wash
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Goodluck.
Jun 06, 2008 | LG WM-1832C Front Load Washer
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Electrolux ewf 1029. What's wrong with it?
Something not working? Problems which you can resolve yourself, before calling the After Sales Service.
During machine operation it is possible that the end light
4 flashes= the door has not been closed
2 flashes= the machine does not empty
1 flash= the machine does not fill.
Once the problem has been eliminated, press the START/PAUSE button. In the case that the blown fuses due to consumption exceeding 10 amps and also have problems with the front cover microswiche which is not activating when you close the door. You should check the condition of the engine and change the microswiche of the door. Remove any objects from the pump impeller by rotating it.
Jul 28, 2011 | Washing Machines
Servicer with a PLMV169DCD Fuse blowing Problem
For future reference, we regularly repair such control boards and displays for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Here's the main service manual. Other versions are here and here.
It may be grease inside one of the switches or arcing conductors (usually due to opening the door while it's cooking) making it sticky.
This was made by Sharp, so the side panel should come off each interlock switch for inspection.
But looking at the schematic, the monitor switch cannot come into play under normal circumstances unless the door is shut and the secondary interlock (relay RY2 on the control board) is closed and (oddly, if the published schematic is to be believed) if the oven lamp relay RY1 is closed .
Everything seems to point to a bizarre problem like maybe an intermittent short of a wire to the chassis, perhaps where a wire passes through a hole or guide in the sheet metal.
Also, you might consider unplugging the hood vent motor and trying it.
Did you try it with the oven powered from another outlet?
Also be sure the neutral and hot are not reversed at the outlet and that the line voltage is correct.
Sometimes a loose neutral can be a factor. Test outlets in several area of the house to see if some are high and some are low. This can be dangerous, and the power company must be called.
If there is anything else on the same breaker, that can be a factor.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 28, 2009 | Frigidaire PLMV169DC Microwave Oven
When I try to turn on my microwave it will not start and "door" shows up on the screen. The light on the inside is not workin either. This unit is 4 years old and we have already have the light fixed once...
The "door" is telling you the door is not properly closed or a switch or two is not working properly. Start troubleshooting with the door switches. One of them is a monitor and is normally closed and opens when the door is closed. it will blow the fuse if it does not open before the other switches close. Very short time frame.
Eric
Jul 12, 2009 | Whirlpool GH4155XP Microwave Oven
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
MAYTAG MAH5500BWW
No power
Lid switch
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Open Questions:
See all Neff 24 in. S5457X0GB Built-in Dishwasher Questions
Neff 24 in. S5457X0GB Built-in Dishwasher Logo
22 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
