Question about Samsung SC-D365 Mini DV Digital Camcorder
How do you close the door when there is no tape in the recorder
    Genius:
  • 1,177 Answers
If it is like my Samsung Mini-DV, it will go in by itself if you close the top part as if you had just put a tape in. There is an outer door, then a kind of drawer that slides out on its own power, then the tape compartment pops up. If you are putting a tape in, you then push that pop-up part down into the powered drawer. It's like pinching the two halves together. You can do the same thing without the tape.There will be a pause, then the powered drawer will go back into the camera and you close the outer door by hand.
Possibly your model is different.
Posted on Jan 02, 2011
3 Suggested Answers
  • 30 Answers
SOURCE: HDR-HC1 video camera won't close after you put the tape in. Hmm
MECHANIZAM fauly.repalace it by expert.
Posted on Jun 21, 2009
SOURCE: Sony video8 won't accept tape (door won't finish closing)
Sony DCR HC 42
I have the same problem as gskillman
Sony says it qualifies for a fla rate repair -- $201 plus taxes!!! Say what? This camera is only a couople of years old and has hardly ever been used.
Posted on Oct 22, 2009
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
Eiki 7070 CD player Cassette Tape Recorder
you could short out the wires that connect to the door close switch or replace the switch.
May 19, 2014 | Eiki LC-XB15 Multimedia Projector
I have a sony cassette deck tc fx44. If I try to insert a cassette am unable to close the door. The door closes just fine without a cassette
Sometimes the tape sensors or record sensor gets bent or out of place so the door wont shut. Look for something like that.
Mar 30, 2013 | Audio Players & Recorders
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Sony DCR HC 42
Jan 11, 2009 | Video Cameras
Gr-ds44 cassette door will not close
I'm having the same problem. According to the manual you should try hooking the camcorder up to AV power to see if the problem is the battery, which is apparently not the problem in my case. Any other troubleshooting suggestions?
Feb 06, 2008 | JVC GR-D244 DV Digital Camcorder
Canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Sep 09, 2007 | Canon XL1S Mini DV Digital Camcorder
Samsung SC-D365 Mini DV Digital Camcorder Logo
129 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
