Question about HP Pavilion dv7-1132nr Notebook PC
I'm unable to reorder the boot sequence or disable the USB drive from the Boot Order on a hp Paviliion dv7-1132nr. Bios is Insydeh20 3.5. Up and down arrows are active but f5/f6 does not disable the drive. What's going on?
    Problem Solver:
  • 10 Answers
  1. press F10
  2. choose boot sequence
  3. disable USB boot
Posted on Jan 02, 2011
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How to disable the f12 option
open your bios, usually f2 or f8, look for boot manager or boot order, then change the boot order so cdrom or disk bay or however your bios refers to your cd drive is first, not sure what you mean by disabling the f12 option.....but changing boot order should fix your problem
Dec 27, 2012 | HP Compaq nc6220 Notebook
Boot hp pavillon zd8000 with usb not possible?
Boot hp pavillon zd8000 with usb is possible.simply plug the USB flash drive with iso and reboot, then press F10 navigeyt Boot Order Mark hard drive, hit enter, Highlight your usb and press F6 so usb was on top of the press F10
May 15, 2012 | HP Pavilion zd8000 Notebook
Boot sequence for compaq evo n800 laptop
You need a system disk first of all. Put the disk in the drive, turn the computer off then reboot. Watch the screen for which key it says to hit to change the boot sequence or boot order. Hit that key when it is shown. This is a one time solution that is only for the current boot process.
To make it permanent, boot the computer an notice what keys it says to hit to get into the Bios or System Setup. Hit that key when shown. You can change the boot sequence or boot order and make it a permanent change in the bios. The most common and best boot sequence is to have the CD drive 1st and the Hard Drive 2nd. Just make sure no disk is in the cd drive when you boot it up or you will get a error saying no boot record or system disk found.
May 01, 2012 | HP Compaq Evo n800c Notebook
I have a systemax desktop that runs XP. I installed a Seagate 2T external hard drive to store pics, files, etc. When I turn on the systemax, it attempts to boot from the external hard drive and will not...
Pressing f10 during system restart will gain you access to the bios. Using the arrow keys scroll to the boot sequence and hit enter. this should allow you to choose from , and select a primary boot order sequence. Follow the on screen instructions to make the changes. Then hit esc button. be sure to save and exit setup.
Jan 23, 2011 | Systemax (036052) PC Desktop
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Ibm not boot from usb
When the system starts up there is usually a key to hit for SETUP, usually ESC, F1, F4, or DEL
Find it, and hit it at the right time.
You will enter the CMOS or BIOS setup.
Once there, locate the BOOT SEQUENCE section and allow a USB boot or external component Boot to be placed int he sequence it it MIGHT work.
Not sure what you're trying to boot from USB for.
Oct 19, 2009 | IBM NetVista M42 PC Desktop
Boots usb first
Hi apicard91
Go into your BIOS and check your boot sequence or boot menu.
there should be a option to disable booting form either a "removable device or external device or usb device"
Just disable that option and then you good...
Please rate the service you recieved
Apr 24, 2009 | Computers & Internet
Boot sequence. I want to boot CD first
No,you don't need to disable quick boot,All you need to change is the boot order.But to boot from CD all you need to do is press F12 while the system is booting up.
Mar 17, 2009 | MSI 865PE Neo2-S Motherboard
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
HP Pavilion dv7-1132nr Notebook PC Logo
805 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
