Question about Vizio L32 32 in. LCD HDTV
My vizio tv won't show any picture, only sound
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
  • 441 Answers
SOURCE: my vizio tv will not show a picture but the sound
try running it on another input, this will tell you if it is just one input or a issue with the whole tv. If you get nothing from any input its time for service
Posted on Jul 07, 2009
SOURCE: Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
Posted on Jul 27, 2009
budmrtn
  • 11361 Answers
SOURCE: Vizio VO420E " TURN ON, tv is showing no picture
It can be the main board, power supply, backlight inverter, etc.
You need to do some troubleshooting to narrow down the probelm, so please read my guide first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Nov 25, 2010
SOURCE: Vizio 42" tv has no picture but sound. What is
the problem is in your 42 tv bec.of your dirt tv ok
Posted on Apr 10, 2011
My vizio model# E480-B2 was working fine one day and the next when I turned it on I have no picture.. Perfect sound ! Does anyone have any ideas?
Hi , The link below is a YouTube page full of videos showing how to fix a Vizio television NO picture GOOD sound, I hope this helps....... CHEERS..
Vizio Tv With No Picture Good Sound YouTube
May 09, 2016 | Vizio Televison & Video
Vizio 55" M550NV turns on, screen displays Vizio symbol for a few seconds then turns black but the tv stays on. What is this and how can I fix it?!
Hi Tiffany, The link below is a YouTube video showing how to fix a Vizio television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
May 07, 2016 | Vizio Televison & Video
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
Vizio TV won't work. We get sound but picture is like distorted and now it won't show video
There are lots of common problems with flat screens that result in those symptoms. Some fixes are super easy and cost $.35 haha and others can cost hundreds not to mention if your doing it your self or not factor in labor. Lots of people sell tv s like that from $50 to $100 bucks and they sell quick! Hell I'd buy it if I had the chance. Could use parts or god forbid find an easy solution ( rare :( )
Mar 13, 2013 | Televison & Video
No picture or sound and tv won't turn off
Check and replace its main power regulator board as card basis.
Sep 21, 2012 | Vizio L32 32 in. LCD HDTV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
I have a 42 inch vizio VW42L and a few months after I bought it sometimes when I go to turn the set on I get sound but no picture. To the point where the backlight of the tv doesnt even turn on. I usually...
Tell Vizio send out the tech.to replace ur Backlight video inverter board,it dying go to be dead sooner or later.Or take the refurbished tv ur tv will have dead video soon.
Sep 07, 2009 | Vizio VW42LF 42 in. LCD HDTV
I have sound but not picture. tv is brand new,
I called Vizio, and was told they could help me, if only I had a proof of purchase. I have called the Casino, and they are working on finding one for me. We will see how far I get with Vizio's help on this one.
Apr 01, 2009 | Vizio VU42L 42 in. LCD TV
Vizio L32 32 in. LCD HDTV Logo
498 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
