My CQ2009F with 1GB of ram running windows XP(x86) will stay in hibernate or standby mode. It will start to go into the mode but only stays in the mode for about half a second and then brings me to the login page.
  • Jeffrey Groves
    Jeffrey Groves Jan 02, 2011
    Do you have your network adapters set to "Wake on LAN"?
    If so, disable this setting.
    Brigadier General:
  • 8,909 Answers
Sounds like you have errors on some files and it is not happy to continue.
Run CHKDSK/F to check for hard drive errors and attempt to repair them. There may be a registry error if you haven't run any utilities to clear them like Norton Utilities or PC-Tools.
Hope that sorts it out for you.
Posted on Jan 02, 2011
I have kept a problem,my laptop FUjitsu Simens Amilo D7850 doesn't get boot and BIOS yet.
You were running Windows XP SP3 and you want to upgrade to Windows 7. Windows 7 and Windows XP are technically very different and apparently your Amilo is not capable of running Windows 7. It requires more RAM, more disk space and also more powerful hardware. You should visit the Fujitsu website to find out if your computer can run Vista and Windows 7. Personally I doubt that.
Dec 12, 2013 | Computers & Internet
How can i upgrade from Windows XP to WIndows 7?
Hey, just use Zinstall XP7. It can upgrade to Windows 7 and keep your programs and files and everything. No reason to stay on XP, I think - 7 is awesome
Mar 18, 2010 | Dell Inspiron 6400 Notebook
Compaq presario r4000 randomly hybernates
Go into the control panel and go into power management or power options and change the standby settings. Its probably set to go on standby mode after 30 minutes without use or something like that
Sep 18, 2009 | HP Compaq Presario R4000 Notebook
Same as above I think
first of all never never never use hibernate only use standby. you want you hard drive to crash and loose all you info keep hibernating your laptop.
Jun 22, 2009 | ASUS Eee PC 901 XP Notebook
At about 3:00 am on thursdays, Windows XP closes and C drive shuts down. It is not a re-boot because the motherboard power stays on. When I turn the computer off and turn it back on (the 1st time)it...
Sounds like the computer is coming from sleep, standby or hibernation mode. Go to the power settings in the control panel, and disable all of these options. Disable your screen saver as well. Leave the machine on for a day and see if it happens again after this. Post your findings, please...
Mar 12, 2009 | Gateway GT5056 PC Desktop
Enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
  1. Click the Start button.
  2. Select All Programs > Accessories
  3. Right-click on Command Prompt and select Run as administrator .
  4. At the command prompt enter
    "powercfg -h ON"
  5. Close the command prompt window.
Nov 27, 2008 | Toshiba Satellite L25-S119 Notebook
Computer does not stay in hibernation or standby mode
That happen because on the stand by or hibernate setting the time was setting in 5 minutes.
Go to Control Panel >> Display >> Screen Saver >> Power
And set the time right there as your preferences.
Oct 01, 2008 | Toshiba Satellite A135-S2276 Notebook
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Want shut down
Click Start, then turn off computer, and make sure that your computer is not set to standby or hibernate. This works if you are running Windows XP or Windows 2000. Hope this helps!
Sep 11, 2007 | E-Machines eMachines Refurbished EMA...
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
