I wonder if it is a simple problem with the vent. The dryer still heats up, but will turn off early and I have noticed lots of humidity in the laundry room. Could it be more than one problem?
sounds like hole in vent especially with unusal amount of moisture..also ckd vent to outside to be sure it isn't plugged ..when reinstalling vent to dryer be sure you don't flatten or compress vent hose to much this will restrict air flow to outside and cause increased dry times or poor drying ..will also cause excess lint accumilation in dryer ..house fire!
GE Frontload Dryer (DCVH515EF model) starts up and heats up just fine, but the dryer turns off after...
(More)
GE Frontload Dryer (DCVH515EF model) starts up and heats up just fine, but the dryer turns off after running just a few minutes. Dryer has been running fine for 2 years, and I have checked the lent trap and venting and all appears fine. Could there be a dampness sensor that has gone bad? Thanks
hello the problem with the dryer is that it display an E01, which i have to assume is some error...
(More)
hello the problem with the dryer is that it display an E01, which i have to assume is some error code. The dyrer will not turn of if I press the power or shutdown the breaker or disconnect dryer from outlet. The E01 still displays everytime. The dryer basically does not work at all.. its like its locked in that mode. Is there any way to perform as master reset? I am sure there is some software in the electronics, is there a way to reset the h/w by doing some type of software reset via control panel? thank you for your support
