Question about Cyclone Folding Treadmill
I have a Cyclone SX9.0 maxpro and half of the rubber on the front roller has shredded itself off. Is it possible to obtain either a replacement rubber sleeve (which may not be easy to fit as, I believe, it needs to be heated into place) or is it possible to obtain a replacement roller. Would you recommend the removal of the remainder of the rubber and retensioning the running belt? Many thanks in anticipation of your advice. Mike
  • Howie king
    Howie king Jul 10, 2017
    Did you try it without the rubber or have any luck with a solution?
Cyclone SX9 0 MAXPRO Treadmill
Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
God bless you
Jun 03, 2013 | Exercise & Fitness
Paper does not feed properly, slips, skids
Make sure the paper guides are properly aligned and spaced if they are adjustable.
The pickup roller may be worn out or loaded up with dust. If wiping it with a damp cloth doesn't help, replace it. (I tried rubber conditioner on one once. While the stuff normally works wonders, in this case, it made the pickup roller break out with little flaps of material all over, and it was still useless.)
Normally a problem with a roller farther into the printer causes the paper to crumple up in an accordion fold and jam, so I don't think these need more than a cleaning, and they probably aren't the problem.
It's also possible you have a foreign object in the paper path such as a shred of torn paper, but a good pickup roller would normally jam the paper into it before the printer halts with an error.
Jun 17, 2011 | Dell 926 All-In-One InkJet Printer
Front rollerhas is rubber coated and the rubber has started to break up ,model is cyclone sx 9.0 max pro
This is a common problem with front roller that utilizes a coating that you described. Treadmill Doctor.com has these sleeves for icon fitness units they may work for your unit give them a shout they are in the state of Tennessee USA.
Aug 13, 2010 | Cyclone Folding Treadmill
Hi there I am getting code c31-23 can you please
This is one of the most common problems on sony camcorders. It is caused by the loosening or loss of the rubber roller inside the tape drive mechanism. Try tapping the top of the cam when the tape is inside. If this doesnt work, open the tape deck and look inside to see if you can spot a single rubber roller inside. If not, then the roller has worked itself loose or gone AWOL missing..:(( However, fear not...the solution for this is to go to an office supply store and obtain one of those compressed air cans used for dusting off keyboards and such. Amazingly, the plastic tip on the compressed air can (where the air comes out) can be used as a replacement for this rubber roller. It fits the metal spindle that formerly held the roller perfectly and allows the cam to function without the rubber roller and without the dreaded C31:23 "your camera is dead and useless and will no longer function" evil Sony message... Check out this link for a discussion of this problem: http://wvstephens.blogspot.com/2008/05/sony-handycam-c3123-3123-error-easy-fix.html
Jul 28, 2010 | Sony Handycam DCR-TRV140E Digital...
Treadmill front roller has a rubber sleever that keep moving
That front roller's rubber sleeve by all rights should not be moving any which way. This mean the roller will have to be replaced call iconfitness @1-888-999-3756 and order a new up-graded front roller .
May 07, 2010 | RTO Image 15.0R Treadmill Walking Belt
Paper Jammed totally removed but indicator still records paper jammed
Here is a very key fix to the problem described:
The 2 rollers which help feed paper get slippery and don't work well after a while. These rollers are found by flipping the unit over (after removal of the toner/drum/paper drawers) and exposing them (they are towards the front of the unit). The two rollers have one rubber band each which provide friction. Just remover the rubber bands (black), flip them "inside out" and replace on the unit. This will expose a new surface, an viola!... virtually double the life of the roller... The other option is to obtain a roller replacement unit from DELL/LEXMARK. They are aware of the problem and have a "kit" to service the unit. Good Luck!....
Jul 28, 2009 | Dell 1720dn Laser Printer
Error C:31:23 on Sony trv27
Jun 12, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Two white spots on printouts
its not hard to replace TBU, remove 2 skrews and open connector and reinstall a new one. but be careful with the new on. also you cant buy only TBU fil, you have to the whole TBU and even if you find new film, replacing that film is a 10 times harder. so its not worth the risk of damage the film.
Feb 27, 2008 | Konica Minolta magicolor 2400 Laser...
Best Cleaning/Maintenence Practice for Scanner
Read your manual or look up Canon Tech Support
May 17, 2007 | Canon DR-6080 Path-Through Scanner
Cyclone Folding Treadmill Logo
407 people viewed this question
Top Cyclone Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Cyclone Exercise and Fitnes Expert? Answer questions, earn points and help others
