Hdd password blocked - Computers & Internet
  • 139 Answers
Don't try anything if your data is important. Just call the toshiba customer support and they will help you out.
Posted on Jan 02, 2011
Won't allow me to gt into my pc .it has be blocked out. and its still under warrenty
Sounds like a password has been put on it. If the hdd password, you must either remember it or purchase a new hdd and start again. Software in not covered by any warranty, only hardware.
Jan 12, 2016 | Toshiba 13.3" Chromebook 2 - Intel Celeron...
System bios has been blocked It is not showing to turn off harddisk && users passwords. So what to do
If you have an hdd password, use it to open your hdd. If not you have two options; Contact the manufacturer and prove ownership. They are the only ones who can help or purchase a new hdd and install your OS and restore your backups to the new system.
Nov 01, 2015 | Computers & Internet
Password hack
While removing the onboard battery and disconnecting all power for 5 minutes may clear the bios, some passwords are written into NvRam (non volitile Ram). This may require you to move some jumpers. Try this.
It may be necessary, on occasion, to clear the CMOS settings. When the CMOS is cleared, all information stored in the CMOS is replaced by default data, which means that all of the configuration information, such as hard drive types and I/O port setup, is cleared, including the password. Use the following procedure to clear CMOS:
  1. Power down the computer.
  2. Remove the left cover of the computer.
  3. Wearing an anti-static wristband grounded to the chassis, remove the jumper from pins 1 - 2 of the Clear CMOS jumper block (JP15) and install it on pins 2 - 3.
  4. Remove the jumper from pins 2 - 3 of the Clear CMOS jumper block (JP15) and install it on pins 1 - 2. (NOTE: Some earlier systems will power up as soon as the jumper is removed from pins 1-2. Later versions of the BIOS change this, 6.00.10 or later.)
  5. Reinstall the cover and power up the computer.
  6. Run the BIOS Setup program to reconfigure the system.
Nov 25, 2013 | Gateway Computers & Internet
Remove password hdd toshiba mk3275gsx
1. The HDD password cannot be removed using Security Assist.
2. Using SETUP BIOS (i.e. start machine; Hold Esc; Press F1), Tab to the HDD Password section which should be displayed as follows:
HDD Password
HDD = Built-in HDD
HDD Password Mode = USER Only
User Password = Registered
3. Tab to the "User Password" field and simply enter the old password and then a new one twice (once to verify) as one would do normally. If you don't want a password, just press "enter" twice.
Hope above steps helps you. :)
Nov 12, 2013 | Toshiba MK3265GSXN - Hard Drive 320GB 2.5"...
Hard-disk #44w4z2y3764-595B the system primary HDD, is protected by password authentication system how to solve this problem how unlock it by correct password?
Here is your Dell Hard Disk Master Password for HDD serial #44W4Z3Y3764-595B
Your HDD Master Password is: w2cuzked
When asked for HDD Password use the HDD Master Password to unlock the HDD password. The Dell HDD Master Password is what Dell can calculate for you or a third party.
Thanks to the great guys at unlockbiosrecovery.com for providing the HDD Master Password that will unlock your hard disk. They can unlock your laptop bios or hard disk.
Apr 01, 2011 | Dell Inspiron 8200 Notebook
I dont now the HDD PASSWORD for LANOVO 4068 , i try to intalate a antivirus and my laptop get blocked and automatical off and ask me for a password . I need a HDD PASSWORD now ! thanks
try to reset the bios password 1st you need to open the laptop case and find the bios battery remove it for about 5 minutes and assemble again wait for about 5 minute and try to swich it on again... hope this help
Jan 04, 2011 | Lenovo 3000 Y410 Notebook
I am locked out the hdd pass word has me blocked
unless you know the HDD password, you will have to replace the drive or pay for it to be unlocked. There is not cheap or free solution to unlock a locked HDD without the original password
Feb 19, 2010 | Acer Aspire 3680 Laptop
My Laptop ASUS A8Jp ask for a HDD password
Hi
Have you tried Debug ? First run a Debug and that will remove everything from the HDD including the partitions and than do a fresh OS installation
Aug 30, 2009 | ASUS A8Jp Notebook
Hdd password reset
Do one thing remove the battery of the laptop in the back side of the laptop after the swicth off your laptop then put in after ten sec and restart the laptop hadd password will be access and bios password also disable.
or do when you start the laptop then press the del button up to ten sec you get it bios setting page after that there is give supervior password give enter twices time your password will be disable.
Jun 04, 2008 | Acer TravelMate 2300 Notebook
There are a number of methods that can be used to bypass or reset the BIOS password, like
  • Using a manufacturers backdoor password to access the BIOS
  • Use password cracking software
  • Reset the CMOS using the jumpers or solder beads.
  • Removing the CMOS battery for at least 10 minutes
For a free software to reset BIOS Click Here:
For more information please check out my solutions, i have allready given some tips on this issue.
Thanks
Iqbal
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
