Question about Dell VOSTRO 3500 Notebook
Dell Vostro 3500 suddenly shut down, start up and works fine, after 2 minutes turn off without any warning message this happened after i installed bios upgrade A10 from dell.com
  • 139 Answers
This is happening because of bios upgrade but not in a bad way. May be there is a hardware problem just starting so new bios upgrade is detecting that and thats why its restarting.
basically sudden shut down occurs in either cases- Fan not working or hard disk(or RAM) gone bad.
my advise is to contact dell customer support and they will guide you thru trouble shooting steps.
they will guide you if your warranty is not there.
Posted on Jan 02, 2011
Testimonial: "thanks for aswering, happy new year!!"
My vostro 3500 suddently shut down quite a few times without warning. the dell helpline made me do a diagnostic check of the hard disk in which some error came up. i was told to back up my data, and then maybe format or replace the hard disk. however, after back up of data, i chose to do a defragment, and then i did the C drive error checking, which is available by right click on the C drive, thru the tools option. after this. certain bad sectors were detected and marked. after this, the laptop is working fine!! :)
Posted on Feb 12, 2012
Water pilled in my dell vostro 3500 , i left it to dry for several days and till now it doesn't work , the screen is off even the power is on , and also fan on , light is fine to. what is the pro
The water is inside the machine on the motherboard and is causing a short, I recommend removing the main battery unplug the power supply open up laptop and lay it face down on a thick towel to assorb any moisture coming out from the keyboard, but I strongly suggest a pro take it apart for a cleaning provided the main board can be saved.
Jul 21, 2012 | Dell Vostro 3500 Laptop
Try going back to the previous version of the BIOS to see whether the problem continues. You can download older versions from the Dell website and install them over the existing version.
If this does resolve the issue, I would report the problem to Dell and as a precaution inspect the fan and the ventilation screens and ducts for debris and clean as required.
If you're good with a screw driver and the laptop is no longer under warranty, you might even consider taking the laptop apart to clean out any dust build-up from the ventilation ducts.
If this answer is any help at all, please rate either 3 or 4 thumbs. (1 or 2 thumbs are considered "horrible" and "bad")
Thank you for using FixYa and have a Happy New Year!
Jan 02, 2011 | Dell VOSTRO 3500 Notebook
I have a vostro 3500, after i installed A10 bios upgrade from Dell.com my laptop suddenly turn off 2 minutes after i turn it on can anybody please help me?
hi eily81,
good day!We have the same problem last time I troubleshoot dell laptop.But I just wait for a minute before I turn it ON..but still turned OFF..so I tried to pull off the battery and power it directly in line.Then keep pressing the power ON..then it begin displaying.
If you can do that..try it.
mastergani
Dell Vostro 200 shuts down with little warning, maybe 30 seconds warning, then just restarts, has been happening about every 24 hours or so for the last week, but today is happening every 20 minutes The...
What kind of warning do you get? i would update the BIOS from dell.com. also, get rid of Vista and get Windows 7. apart from that this could also be a motherboard issue.
Apr 01, 2010 | Dell Vostro 1500 Notebook
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Jun 01, 2009 | Dell Vostro 1510 Laptop
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Dell VOSTRO 3500 Notebook Logo
1,787 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
