Question about Poulan 25CC Gas BlowerVac
Im replacing the pull cord, i have it apart and all that but which way do i wind the cord??
  • 91 Answers
You always wind the cord counterclockwise even in lawnmover.
Posted on Jan 02, 2011
Im having truble puting the starter cord and springs back in my husqvarna weed eater 128ld
You have to take it apart, get the spring back in, then wind the cord around around it. Not an easy task if you've never done it. A small engine repair or lawn mower repair shop will fix it pretty cheap and fast.
Apr 22, 2016 | Husqvarna 128 LD Weedeater
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
Husky rototiller
Without a tool for it, its slow and difficult. Put the hook on it in the little opening in its hub. Wind it in an inch at a time. Be careful. It will probably fly out a couple of times on-till you get it right. Don't let it hit you in the face. Good luck. Also, watch the way the rope pulls to wind it in the right direction.
Oct 19, 2013 | Garden
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
Pull start cord got pinched. Dumb me took off
Yes you can put the spring back in but it takes patience. Wind the spring inside the pully first. Then install the cord on the outside of the pully. Make sure you wind both in correct direction. You probably should replace the cord while you have it apart. The parts would be listed by the engine brand and model number, not by MTD. Probably a Briggs & Stratton engine? You can go to their web site :www.briggsandstratton.com to get part numbers. Or you can try a place like www.jackssmallengines.com
Jul 18, 2010 | Mtd 22" Yard Machine Push Mower
Pull handle has snapped off ,just wondering how to wind it back on
There are many models, and different methods. Most require removing the top engine cover. The cord winder will be inside or still on engine. Some are then simple to replace cord. REPLACE THE CORD, don't cut it off and re-attach the handle. Some are a bit tricky to get the re-winding spring back in position. Patience, and remember what you took apart.
Jul 01, 2010 | Garden
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Pull chord won't go back in
The Rip Starter pull cord? A sprin usually winds it back in automatically. If yours is running (or not) and cord is hanging out, the thin is jammed, the spring is broken or disconnected, or there is a bunch(!) of **** in there gumming it up.
Rap on it with a screwdriver handle, oil it, take it apart and see.
Mar 26, 2009 | Garden
Broken starter cord to petrol generater
You have to tighten the spring inside where the cord goes. The pull cord pulls on leverage by using a clock like spring like a lawn mower. You have to take it all the way apart. The cord part. To get to the spring.
It is strange answering this in a computer section. I answer computer questions and this is certainly not a computer question. Unless you have a wind up computer. Now I have heard of these. Where are you located, if this is a wind up computer.
Jun 03, 2008 | Computers & Internet
Poulan 25CC Gas BlowerVac Logo
141 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
