Question about Baumatic Dishwashers
Hi, i have a baumatic BDI631 dishwasher.it is 11 months old. When i press the power button and select program then shut the door it beeps tho nothing happens. The salt light is on and their is a plate light flashing.
SOURCE: FDW60 flashing 'eco' light error
I had this problem and discovered it was due to a leak. The float switch attached to the bottom panel was operating. Pull out the mains plug, tip the machine on it's side (water will escape so get a mop ready), remove the bottom panel, 3 screws front and back, disconnect the connector from the float switch. Tape the connecter up out of the way and stand your machine back up. Try running it now. If you have a leak somewhere then you will get a puddle under the machine. If no leak, then I would suspect the float switch itself.
Posted on Apr 13, 2007
SOURCE: Baumatic dishwasher won't start
Had this problem with the Baumatic 13. Perhaps the door is not closing properly. Make sure you push the door hard in the top centre. It should beep once and then start after a few secoonds.
Terry
Posted on Dec 28, 2007
IFIXALL
  • 868 Answers
SOURCE: hi just had new dishwasher
Rinse aid is always needed for ALL dishwashers to properly operate.
Posted on May 26, 2008
SOURCE: baumatic dishwasher lights flashing beeping
Easy...dump it and get a new one.
Posted on Aug 07, 2008
daba2
  • 10 Answers
SOURCE: BAUMATIC BFD47SS dishwasher won't start
Sounds like the water inlet solenoid valve is not opening. Not easy to get at to test, but if water is available at the hose inlet connection as you say there isn't anything else stopping water entering the wash cabinet.
Shouldn't be a lengthy repair - so I'd recommend getting a quote.
Posted on Oct 05, 2008
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Jan 05, 2015 | Baumatic Dishwashers
The programe wont stars
Dear Sir:
You must fit very well the door catch. The switch is the elements most important for to run the dishwasher. Otherwise you must waste your time.
See the diagram attached, and you will the switch door must be close for to close the starting relay for RUN the main motor.
sincerely. God bless you
May 04, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
My dishwasher from ikea renlig dw 60, is 6 month old and now the light to select the programs stay red all the time and pressing the selection button doesnt do anything. Thanks for your help
Similar just happened to us. Turned power off, waited a while, opened door. pressed and held power on button then pressed and held also the select button. Brought it back to life. End leds lit up and i could then select and worked when i shut the door. Ours is a smaller Renlig. Good luck.
May 27, 2011 | Dishwashers
Hi there. I have a Matsui MF145 slimline dishwasher and having a problem. When I press the on/off button I would usually then press the program indicator button (usually the first indicator - pans) and...
try to clean the unit, ofetn when the machine is dirty, some sensors are fooled thinking there's some problem. be sure there's no jam on mechanical parts.
Feb 02, 2011 | Dishwashers
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Usermanual for old ADMIRAL dishwasher model number BDUR 41400
right. first of all there are usually three settings one is intence 2 is normal and three is pans. or the other way round. cannot remember. but put nothing in and turn it on by closing the door. turning the knob and pressing the start button when selection is made if no button to start it just select a program and see which one lasts the longest thats the pan one. use dishwasher tables either in the little basket hanging in there or in the door there is a slide thing. put tablet in there and fiddle till it stays shut. then close the door. after loading with stuff. at the bottom will be an unscrewable white knob put some dishwasher salts in there every few months. it keeps the water soft. there is also a filter in the bottom you can lift out to clean a round thing within a mesh grid. that must be reg checked for bits of dinner and stuff. try and get the bets off first. dont put beans and things left on plates and pans in cloggs up. try contacting supplyer for instruction manual. if you cannot thats all you need to know really. hope that helps. liz
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Terry
Nov 22, 2007 | Dishwashers
Door catch
Right on the top edge of the machine - get a torch and look directly under the worktop - there are two hex-head screwws about 4" in from each side. Clockwise to increase spring tension.
May 30, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Dishwashers Logo
196 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
