Question about Samsung Digimax D53 Digital Camera
I put a new sd card in my camera and it says check sd card. It wont let me take pictures what does that mean
  • Samsung Master
  • 4,738 Answers
Your model camera can only use up to a 2GB standard SD cards, and not 4GB or higher SDHC cards. There are several other possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before the SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Jan 02, 2011
Testimonial: "Thanks so much. I did not know that and a 4gb is what I had. That was very helpful and very fast response."
Camera says no file when I turn it on and it wont work
Did you put a mini sd card in the camera. No file means there are no videos or pictures. It doesn't have an internal memory.
Mar 12, 2014 | Emerson Go Action Cam 720p HD Digital...
I put sd card and the camera wont turn on
Dear Noel,
The possible causes behind this problem would be:
1) SD card might be damaged or damaged directory structure.
2) The Camera won't support the existing SD card and sadly, you'll need to purchase a new one.
Please check with these and most probably, you can easily address the issue.
Thanks,
Feb 09, 2014 | Sony Cyber-Shot DSC-S40 Digital Camera
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
I got the e327 photosmart, and I jsut put in the 8gb sd card in the camera. Does not work. It wont even let me format the card at all. The screen turns on but I cant even take a picture. Can this camera...
The E327 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible and will not work in devices not designed to accept SDHC cards. You need to use SD cards, 2GB and smaller.
May 17, 2011 | HP Photosmart E327 Digital Camera
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
My son got a vivitar 8025 and it wont take pictures it keeps telling us the card is protected. What does this mean and how do we fix it?
did you put an sd memory card into it? this camera will not take pics without an sd memory card (it did not come with any memory to hold pics on the camera itself). the memory card needs to be inserted into the slot right next to the battery:)
Dec 25, 2009 | Vivitar ViviCam 8025 Digital Camera
I put a new memory card in our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 1 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.
1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
No image shown
If you took the pictures, and stored them on the camera's internal memory, then put in a memory card, it will read from the card and you wont be able to see the photos that are actually stuck on the camera. Try removing the SD card, then check for your photos.
Conversely, if you took the photos when the card was in, and then removed the card, the photos wont be stored on the camera, so you should look for the card.
Jun 23, 2009 | Polaroid i634 Digital Camera
SD card rejection
I have seen SD cards go defective. Also, enquire to the manufacture of the camera or at least the dealer to make sure that the model of SD card that you have is compatible. I have seen compatiblity issues with particular SD card types on specific models.
Jerry G.
Jun 06, 2008 | DXG Technology DXG-518 Digital Camera
Samsung Digimax D53 Digital Camera Logo
372 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
