Question about HP OfficeJet 6110 All-In-One InkJet Printer
Does the hp officejet all-in-one print wirelessly?
  • 4,472 Answers
The 6110 model does not print wirelessly.
Thank you,
Lee
Posted on Jan 02, 2011
  • 876 Answers
5 Suggested Answers
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
darkpain
  • 316 Answers
SOURCE: How do I print wirless on a HP Officejet H470b
Hello my friend.First you must install the software if you haven't.Insert the Starter CD that was with your printer into the CD drive,the menu runs automatically,if its not double-click the Setup icon on the
Starter CD.On the menu, click the button for the connection method you want to use(wireless).Follow the onscreen instructions to complete the software installation.
After that we are going to create a wireless profile.
Open the configuration utility for your computer’s wireless network card, then do
the following:
Create a new wireless profile with the following values:
• Communication mode: ad hoc
• Network name (SSID): hpsetup
• Security (encryption): disabled
Activate the profile.
Wait two minutes for the device to obtain an IP address, then print a wireless
configuration page.
On the configuration page, verify the following for the device’s network settings:
• The IP address is not 0.0.0.0
Posted on Feb 08, 2010
SOURCE: HP OfficeJet Pro 8500 A909 does not print
i cant print what happening. Its telling me to load paper but i have paper in slot. This started happening after a paper jam.
Wonder Wizar
  • 62 Answers
SOURCE: Connecting the HP OfficeJet 6500 to wired & wireless computers
Use the disk that came with the printer and install the software in both the computers based on the os installed in the individual computers, ping the ip address of the printer from both the computers, and then test for the functionality
Posted on Aug 18, 2010
How do I print wirelessly from my Samsung Note 3 to my HP printer?
Go to the Google Market and download an apps called HP All-in-One Remote and install it in your Samsung Note 3.
Then while your Note 3 and HP Officejet were in the same wi-fi network, your Note 3 should be able to detect the HP printer. Then you could select which documents to print and whether B/W or color.
Jul 26, 2014 | HP Officejet Pro 8500A Wireless All-in-One...
Officejet 6500 wireless has stopped printing ALL color.
Send the cartridges back! HP cartridges are coded and will only work with HP printers. Hp has had problems with their coded cartridges. Especially if they were manufactured overseas. Their own product won't recognize the cartridges. It is not the printer it is the cartridges.
Feb 18, 2018 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 wireless printer won't print quickbooks checks
go to control panel, printers, right click on my printer icon (HP Officejet 6500 E709n), click properties, click advanced tab and check "print directly to printer"
Nov 26, 2010 | HP Officejet 6500 Wireless All-in-One...
I HAVE A MAC OS X 10.4.11. HP OFFICE JET 4500. HOW DO I SCAN? WHAT OPENS ON MY COMPUTER? WHAT SOFTWARE SHOULD I HAVE? I SAW I PHOTO OPEN BUT DID NOT SEE MY DOCUMENT.
OS X driver which allows your Mac to interface with a HP Officejet 4500 wireless all-in-one printer
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 13, 2010 | HP Office Equipment & Supplies
Jul 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Wireless printing to HP officejet Pro 8500 Wireless Printer
Open "Control Panel".
Open "Printers".
Click to select the printer.
Click the "offline/online" button, to mark it as "online".
Print.
Apr 10, 2010 | Computers & Internet
HP OfficeJet Pro 8500 A909 does not print wirelessly from my MacBook Pro with OS 10.6.2 (Snow Leopard). How can I get it to print wirelessly?
Jan 07, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Wireless Printing Upgrade Kit - HP G55 Officejet Printer?
Yes ; The Officejet 6000 series os one of thse listed on the HP website under the "Wirless upgrade kit" that is compatable.
Feb 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
235 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
