Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Our washing machine fills with water for 1 to 2 seconds, then pauses. It repeats this but will obviously not fill with water. Can you help me?
My washing machine does the same thing. It won't move on to the tumble cycle to actually wash the clothes. I end up cancelling it, unplugging it from the wall (trying to reset the computer) and starting all over again. Sometimes this works, sometimes it doesn't. I find I have to sit there and babysit it to make sure it moves on and cleans them. So frustrating. I switch it from Normal to Sport, or a different type of wash cycle and sometimes that helps, and sometimes not. I am on this site trying to research and get help also. Good luck, hope we can find solutions. :)
Posted on Jan 10, 2011
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool duet Washing Machines
After selecting the wash programme sounds as if machine about to fill with water but at this point it defaults to start/pause. Have tried selecting reset/skip button but repeats the same problem, please...
Is there any water filling into the machine? If not then the filters on the machine may be clogged up and need to be cleaned? There is also a filter on the hose of the machine where it connects to the water mains pipe.
It just means removing them and rinsing them under the tap.
May 22, 2011 | Washing Machines
Bosch WFT 5010 washing machine will not fill. The timer seems to work correctly - the washer goes to the set program and pauses - at this point the fill valve opens normally. But it is not happening. ...
Possible that the inlet valve is faulty but you will need to check the voltage at the time of the cycle. Even if this valve is clogged at the inlet filter it will not fill. so check from the front end, remove the water line and check.
Please find some tips from the link below;
http://www.washingmachineadvisor.com/how-do-washing-machines-work-.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Feb 19, 2011 | Washing Machines
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
