Question about RC Raptor G2 Replacement Parts: 50H08 34 Tail Servo Holder
How is a 50H08-42 battery used?I cannot figure out how to connect it and what it is for....
Why does the kicker CX1200.1 have no fuses and how then do you determine what fuse to use for the battery connection?
that amp has Fail-Safe Integration Technology. i would recommend a 100amp large plastics case glass fuse. install closes to the battery red terminal
Oct 19, 2014 | Kicker CX Series 1200W Class D Mono...
E300
Im not sure I understand your question. The E300 runs on 2 batteries at a time and they recharge in the unit. To replace them clnnect one + to the other - and the remaining + and - to the unit.
Sep 08, 2014 | Razor E300 Scooter
How to charge battery for first use
under the seat, lift the battery out and disconnect from vehicle then plug the charger into the batter
Dec 16, 2012 | Fisher Price Power Wheels Kawasaki KFX...
Connecting 2 UB6120ZH batteries for a peg perego jeep.
if it is 2 6v batteries wired in series, then the main leads would be connected to the positive of one battery and the negative of the other battery, and then another wire would connect the remaining terminals of the two batteries together
Jun 06, 2012 | Toys
How to connect 2x12v batteries in series
connect a wire to positive terminal of first battery, and then connect a wire to the negative terminal of the second battery, then connect a wire from the negative terminal of the first battery to the positive terminal of the second battery
May 18, 2012 | Toys
Hello.I've got an Asus K52JE.Today I looked at the
97% isn't that bad, it means that your battery is fully charged but not the whole way. That is bound to happen specially when youre using youre battery a lot. It will get a lot more lesser in the future the more you use youre battery.
The standard laptop battery starts losing the ability to hold a charge after 300 recharges or cycles. If you drain your battery almost completely at least once a month and then recharge it, it will last longer & hold a full charge longer.
Jul 09, 2011 | ASUS Computers & Internet
Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Mar 13, 2010 | Casio PRG-40T-7 Pathfinder
Lost directions to charge battery
you need to charge the specific power wheels charger into your battery.
I have a power wheels jeep and a peg perego gator but had to get 2 different chargers for them.
I charge my batteries up for about 18 hrs at a time and they seem to run fine.
Apr 25, 2009 | Jeep Yellow Sports Outdoor Power Wheels...
Will the battery still work if the battery latch is gone? I just got a battery charger an am charging the battery and figured someone could answer this ?
The latch is required to hold the batteries firmly in place. Also, on the battery latch, you have a piece of metal which connects the positive side of one battery to the negative side of the other battery. So if you can place a piece of metal or use a wire to connect the two batteries, and then hold the batteries in place somehow, your camera will work.
Feb 26, 2009 | Fuji FinePix Z10fd Digital Camera
Rewiring an old pioneer stereo.the radio was installed where it powers without the ignition being on.the battery was draining. figured it had to be the radio. pulled radio. the red power(acc wire) was...
hello...if you are sure that the red wire is acc it should be connected to the acc connection of the ignitionkey.or maybe the lighter positive...and the other to the battery"always 13.8 v"...then the memory will function properly of the radio and you will not drain your battery...please tell me what happens...good luck ...Ron
Mar 07, 2008 | Audio Players & Recorders
RC Raptor G2 Replacement Parts: 50H08 34 Tail Servo Holder Logo
27 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
