Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
My dishwasher will not drain the water. Is there a quick fix
  • Mark Carey Jan 02, 2011
    Can you hear the pump come on?
  • lisa_troup Jan 02, 2011
    yes, it will do the entire cycle just not drain
  • 50 Answers
There is a drain hose that runs under you sink
It will run into a drain pipe under the sink or into the disposal
Remove that hose and check for obstuctions by pumping into a bucket
If that doesn't work check the drain in the bottom of the dishwasher.
There is a filter there that may be plugged.
Hope this helps
Posted on Jan 02, 2011
I have a samsung dishwasher that won't drain it makes a cracklings noise then the quick light starts flashing if I unhook the drain line and hold it lower in a bucket it will drain
If it is making crackling noises, it has water on electrics and is shorting out. Unplug it a call a technician before you have a fire.
Unhooking the drain line and lowering just allows water to flow past the pump.
samsung dishwasher Google Search
Jul 10, 2017 | Samsung Dishwashers
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
There is water on the bottom after a full cycle.
Water at the bottom of your dishwasher after a wash cycle indicates a drain issue. Please check out my quick tip on how to fix this issue.
http://www.fixya.com/support/r7229617-quickest_way_fix_drain_issue_dishwasher
Please rate me "4 thumbs" if that was helpful.
Dec 15, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
My dishwasher wont drain the water
Check out my quick tip on how to fix your drain issue.
Have a great day please rate your experience
Dec 12, 2010 | Whirlpool Dishwashers
Bad smell coming from bottom - water doesn't completely drain out
Make sure the drain hose is not blocked or pinched.Also check where it drains into your sink pipeing to be sure food isnt blocking the drain way.
Its eather the drainage path is blocked or the pump stoped pumping.
Also, the drain hose must be installed so as to have a high spot higher than the sink drain or the water from your sink will be able to "run down hill" or drain into your dishwasher. Take a look and see!
also It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Aug 17, 2010 | Bosch Dishwashers
Kenmore dishwasher water will not stay in there
It sounds like you have a drain hose problem. The drain hose needs to have a rise in it. If it is going down hill or to a drain that is lower than the tub it can drain as fast as it fills.
Apr 24, 2010 | Kenmore Dishwashers
I have water dripping from the bottom of the dishwasher where the drain line connects
there is and you can find it at a resturant equipment dealer. if you need to have a quick fix untill then. silicone sealant will do in a pinch.
Aug 28, 2008 | Hobart AM14-253 Free-standing Dishwasher
Water is not draining
Your drain pump might be bad/disconnected. Check the underside of your machine for disconnected wires.
Dec 17, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
96 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
