Tip & How-To about Dryers
PF- Power failure. Recommend that you press and hold the start button to continue the cycle or press off to clear the display.
E1- Open temp sensor Recommend that you replace the temperature sensor
E2- Shorted Tempurature sensor. Recommend that you replace the Temp sensor.
E-3- Blower rotation failure.Recommend you check the motor and replace if needed.
E-4 Tumbler rotation failure.Recommend you check the motor power.
E-5 Dry rack sensor error.recommend that you check the sensor and replace if needed
E-6 Exhaust high limit fault. Recommend that you check your exhaust and clean if need or replace the sensor
