Hi the burner is working on the water only,no heating. when the heating is on or the water is off makes no difference
  • Barrett Palumbo
    Barrett Palumbo Jan 02, 2011
    Sorry to hear about your issue.
    But you have entered your problem, in the wrong area.
    Example: I have a broken PC, and its posted under ovens.
    In addition, please give the make and model of your unit.
  • Bluvenom Jan 02, 2011
    What's the year,make & model of your vehicle? Eng. size too. Be more specific about your concern please? Thank you!
    Sergeant:
    Champion:
  • 426 Answers
Change the tank it may be bad
Posted on Jan 02, 2011
New heat exchanger fitted still not heating
The heat exchanger is everything above the fire and makes the heat available for ducting. The combustion chamber supply\'s heat to it from either a burner or heating elements. Does your burner light or elements get hot? Check for power turned off.?
Nov 11, 2013 | Bosch & Power Vent Water Heater
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
I have a new Atwood 6-gal propane water heater (still under warranty). It works fine except that when warm water is flowing, the burner will start heating only after the water gets quite lukewarm. Can one...
If it's manual light, then only dial or lever on gas control is adjustable, and you can try turning it up a little at a time. It will increase water temperature so be careful, but that should also make it kick back in sooner as well. If it's electronic ignition, there is 2 or 3 heat settings available in thermostats ( little disc behind foam cover under pressure relief valve) . Obviously on those, if you choose higher temperature, it cuts back in sooner as well. If you have electric element, they have a thermostat on rear of water heater as well, behind electrical connection box. If your not 100% sure what I'm saying here, get back with model number of heater inside cover and I'll tell you your options. Please remember to be careful of scalding when you turn up the temperature.
Oct 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
Riello oil burner RDB Hi everybody i have a Riello oil burner RDB . I am wondering is there a way to make it more oil efficient?
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
Sep 25, 2010 | Heating & Cooling
I paid to have jahn27 solve my problem with kenmore model 70172 dryer (burner cycles such that clothes don't dry. he recommended replace of both burner coils which i did but burner still cycles). how do i...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 11, 2010 | Dryers
Water in resovoir boils away. Do I need a thermostat?
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
Dec 02, 2009 | Bunn VPS Coffee Maker
Top burners are propane. we are used to propane heating really fast. this stove seems really slow. 5minutes to boil litre of water. burners are having hard time lighting.
If it is new fromt the factory, you many have the natural gas (methane) jets in the burners. You will need to check your bag of parts to find the propane parts (LP parts). LP jets allow a different fuel/air mixture to burn at the right heat. Check the owner's manual for details how to make the change.
Please rate me - Good luck.
Nov 20, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Coffee maker stoped working
  • Make sure the power supply is all rite (if not try with different socket)
  • If your able to seee light..then try re-programme it using buttons.
  • Still if you face same issue ..i request you to call technician.dont try any thing,Give it to safe hands
  • Thanks
  • Jul 22, 2009 | Gevalia 50041 / 50443 Coffee Maker
    Parkray Cumbria efficiency problem
    Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
    Nov 25, 2008 | Water Heaters
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
