Question about HP Computers & Internet
My HP starts but when I turn on monitor the light goes green then turns yellow and nothing happens. What is the problem? Thanks!
  • 158 Answers
Turn on monitor first then the hp if all is well just remember sequance if not then check cable to monitor from hp if it can be replaced then replace cable but check hp with another monitor first just incase the monitor is gone.
hope this is helpfull
Posted on Jul 09, 2008
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
May 15, 2011 | HP Compaq WF1907 Monitor
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Nothing is showing on the monitor
just your monitor back panel open next monitor neck board put dry solder
Sep 26, 2009 | Compaq Computers & Internet
Monitor turns off: Light goes from green to yellow
Check first your signal cable from cpu to monitor, reseat or retighten its nut. Or test it using an spare monitor, if this also happens. If it does not then its practical to have the monitor be replaced.
Other way around like fixing its cable is also a consideration it maybe also a broken connection.
May 25, 2009 | HP Compaq FS7600 17" CRT Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
HP desktop monitor problems
Motherboard is detecting an error. 1st and most likely to test is power supply to see if it is weak. I did work on one last month of about this model and the bracket for one of the bridge chips broke. You might look inside to see if it's still securely attached. It will be the heat sink below the processor. Keep me posted - Scotty
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Blank monitior
There is probably some electronic malfunctions inside your monitor. Since I will not be able to actually check your monitor, the best solution for this is bring your monitor to a qualified TV/CRT technician in your area for proper diagnosis. He's the right expert and the second opinion to that kind of problem. Problems regarding inside the monitor are usually not fix-it-yourself kind of thing for non-expert like you compared to software problem, which can be mostly fix by yourself guided by an expert.
Sep 12, 2006 | HP Pavilion MX70 17" CRT Monitor
Computers & Internet Logo
120 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
