Question about GE Nautilus 24" Built-in Dishwasher
Suds won't drain out of bottom ?? - GE Nautilus 24" Built-in Dishwasher
  • 1,543 Answers
There should not be suds in your dishwasher. If there is, it mean someone used dish soap instead of dishwasher detergent in the machine. To resolve this problem, get a package of Phyzeme (not correct spelling) stomach gas releif from the drug store, snip open about three of four capulets and squeeze the contents out into the dishwasher water after it has filled. Restart the dishwasher for 10 to 15 seconds and open door to see suds all knocked down. Close door and hit reset to allow pump out.
Mr Scott would say:
Oh, ya didn't go and tell them the truth now did ya laddie? How are they gonna think you're a miracle worker?
Posted on Jan 02, 2011
My Smsung dishwasher always has suds in the bottom after cycle has completed
Couple of questions?
1. do you have a water softener?
2. what type of detergent are you using and how much?
3. is the detergent HE rated?
To clear out the suds run a cup of white vinegar with 4 liters of cold water and run a rinse cycle. or just put a cup of white vinegar into the dishwasher and run a normal load with NO SOAP... you need to clear the suds from the system to work properly again. the proper detergent to use in most new dishwashers is powder style that is HE rated. and don't use a lot either.
Sep 17, 2012 | Samsung DMT300RFS Builtin Dishwasher
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
Washer won't drain, rinse or spin
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
It won't drain or sometimes it drains slow.The F2 code will appear or the Suds code will show up.
The drain filter is blocked and needs to be cleaned. Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel
underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it.
Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
Click on the link below if the problem persists after cleaning the filter.
Kenmore Elite and Whirlpool Duet Sud/F02 Error Code
Jul 20, 2011 | Washing Machines
My whirlpool washer (model: WFW9400VE) - is not draining properly. The water just sits there and different codes keep coming up on the display. I get the following two codes: 5-UD and S-21. What does...
you may have something stuck in your drain pump. could also be a problem with your drain line, make sure drain hose is not kinked and is not 96" above the floor. if our drain line is ok. then remove bottom panel of washing machine. the drain pump will now be visible. turn the tab on the drain pump, make sure you have some towels, because water will be coming out, stick your hand inside and see if there is anything stuck inside.as far as the sud error code, the drain pump is designed to remove just water and not suds. If you are not using he (high efficiency) detergent and following instructions for the desired amount. you will get that code. Also this machine should activate a sud cycle to remove excessive suds
Feb 03, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Sep 22, 2009 | GE Washing Machines
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking suds out the bottom and no draining of water
did you recently install a garbage disposal? suds coming out is from too much soap or hand soap making suda which come out over the tub. the no drain is from a blockage or bad pump or divereter depending on model
May 15, 2008 | Kenmore Dishwashers
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Sep 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE Nautilus 24" Built-in Dishwasher Logo
113 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
