Question about Nitro BMW-486 Car Audio Amplifier
My 2000 watt nitro amp just stopped working need help
I have a nitro 2000 watt amp fom my 2 12 inch subs but just the other day my amp just stopped working it wont turn on or anyhing i replaced the fuse but that didnt work i dont know what the problem is i only had it for 10 monts what should i do Help me plz
  • Anonymous Jan 24, 2009
    my 2000 watt nitro amp just stopped working. power is going to the amp but it wont turn on
The problem could be our ground or our remote
Posted on Dec 16, 2008
  • 1,498 Answers
Think about anything out of the ordinary that may have happened the day (or day before) it quit.
  • Was work done to your system?
  • Did someone mess with your system?
  • Smell anything odd?
  • Especially loud?
  • Did it quit mid-song or did it work yesterday and not today?
Assuming nothing special, here are some diagnostics you can perform. At the very least, they will help tell you what the problem isn't, First....
Eliminate power supply problems.
Use a meter to make sure you have power to your amps +12v terminal. A meter is preferred over a test light to confirm a full +12 volts.
Make sure the ground terminal is grounded. A meter with a continuity test option is best for this.
If either of these fail, trace the wires to find the fault. Large amps like yours normally have dedicated power cables. These cables usually have an additional in line fuse close to the battery. Check it.
If they pass, double check the amp fuse.
Pull the wire (usually blue) from the 'remote' terminal on the amp.
Then try jumping the +12v line to the remote terminal.
If it still doesn't power up, check for signal shorts.
Turn the gains down low.
Pull the input lines and try the +12v to remote jump again.
Next pull the speaker wires.
Your amp should now have only two wires and a jumper attached to it. Try the same jump.
If it still fails, the problem is in the amp itself and (I'm sorry to say) leaning toward the serious.
Hope this helped
Posted on Jul 11, 2008
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
Is two comp 12's with a 1200 watts nitro amp a
The 1200w rated for the amp is usually an absolute maximum output, the rated output is more likely about a quarter of this figure (300w) I think for the subs you are looking at, you would be better off with a more powerful amp
Hope this helps
May 06, 2011 | Kicker Car Audio & Video
How should i wire my sub
if your amp has a bridge do nt bridge the subs just connect them normal planet audio subs usually dont have a high potential to withstand too much watts even if the subs say 1200 watts thats not true nwatts check the box the subs came in it will tell u true wattage it may say rms
May 24, 2010 | Nitro BMW-481 Car Audio Amplifier
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide... that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
What size amp should i get for performance teknique sub-woofers
the amp you have will do the job depending on how may ohm you sub is and can you amp stable to handle low ohm's. you should also check your cabling to make sure its for about a 1500w amp so you dont lose any power
Sep 17, 2009 | Nitro BMW-482 Car Audio Amplifier
What makes a nitro 1200 watt amp go to protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. makes-nitro-1200-watt-amp-go-protect-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Aug 02, 2009 | Nitro BMW-482 Car Audio Amplifier
Subwoofers were said to be bad
overpowered definitely. when you bridge subs your almost doubling the power. if the subs were set for 2000 then the guy he took them too should have known better or at least turned the power down on the amp.
Mar 13, 2009 | Car Audio & Video
The fuse from the amp to the battery keeps burning
maybe it cannot accomodate too much power running on it...too much current, try another fuse with higher ampere rates
Jan 14, 2009 | Nitro BMW-486 Car Audio Amplifier
Is Sub Underrated for my Amp?
fuses wont restrict the current flow the amp is way too much for that sub. it may not have damaged that sub yet but it will. you might only need a 100 watts rms too run it.but you will need sowe where about 2000 watt sub too run off that amp
Dec 28, 2008 | Pioneer TS-SWX310 Car Subwoofer
Nitro BMW-486 Car Audio Amplifier Logo
760 people viewed this question
Top Nitro Car Audio & Video Experts
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
